I'm trying to burn a copy of a SVCD I have. I'm using EZCD Creator5. The orignal movie that I'm attempting to duplicate is on CD-R (700mb/80min) While in EZCD I'm burning a Data CD and simple drag & drop the drive contents into the recording area. The estimated project size is 792.3mb
How in the hell can you do that. I did not create the master copy. Is there an authoring solution that can use some sort of compression / or allow overburning?
Don't worry about the 792.3MB, make an image file or ISO file and burn it in image mode with Nero Burning rom or use CloneCD.
S/VCDs are not CD-ROMs and you cannot copy them as such. Even if you have a small VCD so that it will fit, the resulting disc WILL NOT WORK.
You will have to do a proper DAO copy. This is the best way of copying not only VCDs, but ANY CD. This is most simply accomplised by use the "disc copying" function of your CD-burning software.
Some proggies are better than others, and I highly recommend Clone CD or CDRWin for copying CDs.
Regards.Michael Tam
w: Morsels of Evidence
Burning to Full Capacity of a DVD
By Agent 5 in forum MediaReplies: 6Last Post: 16th Apr 2012, 09:49 -
windows 7 64bit and secondary data 3TB HDD not visible in full capacity
By deejay.2001 in forum ComputerReplies: 14Last Post: 21st Jun 2011, 15:08 -
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 17:53 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 19:48 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
