I tried lossless-cut, FFmpeg Batch Converter and the results are the same. Mediainfo is saying the output frame rate is variable instead of constant like the source file. I thought it might just be a meta data issue or something, but it messes up the frame rate in Adobe Premiere as well when importing the file from lossless-cut and FBC.
Most of the time it's just a straight copy from mkv to mp4 and other times it's just encoding the audio. It shouldn't really be messing with the frame rate. Anyway to make it properly output the correct data so other programs read it properly as the source frame rate?
The problem probably is the default time base of 1/90000 seconds. The duration of frames for a 23.976 (24000/1001) fps video cannot be precisely represented as N/90000 seconds per frame, where N must be an integer. 1/(24000/1001) = 3753.75/90000. If the program used 3754/90000 for each frame (CBR) the video would run a little long, if it used 3753/90000 it would run short. So it alternates between the two values (VFR), 3754 for three frames, then 3753 for one frame, repeating that over and over, giving an average of 3753.75/90000.
I thought you might be able to work around this by specifying "-time_base 1001" or "-time_base 90090" but it doesn't appear to be that simple. In any case, it's generally not something you need to worry about. -
I've only seen it with MP4 and MOV. If you remux such a file to MKV it becomes CFR again.
@kkiller23: make sure you specify the input frame rate before and after the input ('-i ....'). I ran into this a few days ago and that is how I fixed it.
Making a Variable Frame Rate video
By Mr. Anderssarian in forum Video ConversionReplies: 3Last Post: 1st Jan 2019, 17:17 -
transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)
By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 05:01 -
Variable frame rate into constant frame rate without re-encoding
By DunnoNo in forum Newbie / General discussionsReplies: 8Last Post: 21st Dec 2017, 11:05 -
changing Frame rate results in video stuttering
By anime12345 in forum Video ConversionReplies: 4Last Post: 10th Jan 2016, 11:55 -
Avidemux Variable Frame Rate
By ThatFox in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jun 2015, 04:01
