It works fine in the capture program it comes with, but I'd rather capture with less compression. I have the drivers downloaded, I can only get a video to appear in virtualdub2 64 bit if I have it set to "Microsoft WDM Image Capture (Win32) (VFW)" but even that captures odd, it doesn't deinterlace correctly. The device "Hauppauge Cx23100 Video Capture (DirectShow)" does not show any kind of preview and will have an error when trying to capture. Only on virtualdub 1 (64 bit) does it show a black screen when set to overlay. I can change all the settings for it though and everything appears normal but it just doesn't work. I did try changing the settings around but still nothing.
Does anyone else who uses this have any ideas? Do I need any other software or drivers to get it to work?
Results 1 to 17 of 17
I may be wrong here but I do not think that vdub can capture with DirectShow. It must use a vfw driver. That is what I use with this device.
If you want to use the Hauppauge with DirectShow then use Dscaler
And if you are capturing interlaced footage such as VHS then never, ever, try to de-interlace at the point of capture. -
I'm not trying to capture it as progressive but it appears the VFW is capturing as progressive, how can I change that? In this tutorial with another DirectShow device it does work for them: https://youtu.be/sn_TDa9zY1c
If using VFW is right I will use that but I want to make sure that it is the "correct" way so I don't have to redo it if there is some problems with that -
Where can I see that in mediainfo? When I go in VLC and go frame by frame (with deinterlacing off) it has two frames obviously interlaced then two or three which look like they aren't then back to two interlaced frames, and repeating that pattern.
My apologies.
DirectShow does work for this device.
1. Select it under the Device Menu
2. Select 'Capture Device' under the Audio Menu. Don't ask why it works that way but it does. -
I think you are right it is interlaced, I put it through QTGMC and it deinterlaced totally fine, but for some reason playing the interlaced file in VLC doesn't seem to work well with its real time deinterlacing, at least for me. Well if QTGMC works then that's all good I guess, I'm not really going to be looking at the originals. (I am keeping them though)
Thanks. -
Try VirtualVCR. It works with the Hauppauge Cx23100 DirectShow filter.
http://virtualvcr.sourceforge.net/ -
A lot of people report success with amarectv after having problems with VirtualDub. You don't need their $30 codec. It can use other system installed codecs.
I captured my whole vhs-collection with Hauppauge USB-Live2 a few years back. I tried VirtualDub but could not get it to work so Amarectv was what I ended up using. With Huffyuv.
Video/Audio sync problems with Hauppauge USB-Live2 & Vdub
By liddle in forum Capturing and VCRReplies: 34Last Post: 30th Dec 2025, 08:15 -
USB-Live2 Proc Amp Settings in VDub Don't Work
By koberulz in forum Capturing and VCRReplies: 26Last Post: 5th May 2020, 15:44 -
USB-Live2 Brightness Issue (Video Example)
By JawsTDS in forum Capturing and VCRReplies: 8Last Post: 5th Jul 2019, 06:25 -
Hauppauge : USB-Live2 (Green bar at bottom, 20% of the screen!!!)
By Keitaro004 in forum Capturing and VCRReplies: 24Last Post: 7th Dec 2015, 00:43 -
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 10:56
