I'm seeing if anyone knows of a bat file that I can just drag a video file onto and increment the filename every time I drag a video file to the bat file.
It would have to check for previous filename, then ffmpeg will render it with an incremented filename.
Eg: Scene_001.mov and Scene_002.mov already exists in the folder. When I drag the video file to the bat file , it should render it as Scene_003.mov.
Hope that makes sense.
Help appreciated.
this should work, fill in/correct underlined parts :
Code:@echo off setlocal EnableDelayedExpansion SET "ffmpeg=your_path_to\ffmpeg.exe" SET "output_folder=D:\rendered_files" SET "extension=mov" SET "prefix=Scene_" rem do not set this, just define it empty: SET "output_path=" call :get_output_path "%output_folder%" %prefix% %extension% rem here goes your ffmpeg command line where %1 is input file and "%output_path%" is your destination "%ffmpeg%" -i %1 ..... your filters end such ..... "%output_path%" echo Done endlocal & echo press any key to exit ... & pause>nul & goto :eof :get_output_path <output folder> <prefix> <extension> SET "i=0" SET "formated_value=000" :loop SET "output_path=%~1\%~2%formated_value%.%3" if exist "%output_path%" call :increase& goto :loop goto :eof :increase SET /a "i=%i%+1" SET "value=000000%i%" SET "formated_value=%value:~-3%" goto :eof
ffmpeg 4.1.4 question regarding "limited color range" output file
By bokeron2020 in forum Newbie / General discussionsReplies: 12Last Post: 1st Aug 2019, 17:28 -
How to set ffmpeg File Path on Batch File
By Daringbaaz in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2019, 05:55 -
Batch file to create nfo files for multiple videos
By olpdog in forum ProgrammingReplies: 2Last Post: 16th Jul 2019, 12:47 -
Can I use ffmpeg to create a script to download links from a .txt file?
By Serenity23 in forum Video Streaming DownloadingReplies: 0Last Post: 1st Dec 2016, 21:55 -
Can I get a little help with an ffmpeg script/batch file?
By Iced Coffee in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2015, 01:56
