Not sure if this is the right place in the forum to ask.
Is it possible to speed up video playback to restore original playback speed? without screwing up video?
some TV networks i noticed speed up TV shows so they can fit more commercials, so instead of the original 44min, its now 41min.
So, you set a lower framerate than what it already has. That can be done with some videos formats, but it'll throw the audio out of synch so what's the point?
can be done, but not without loss, as the networks either do that through editing, or through time compression which BLENDS frames, so slowing down won't get rid of the blends, and could very well add more if you don't do it correctly. And as was mentioned, the audio would need to be correspondingly time-expanded also as well to maintain sync (though audio is MUCH easier to do in that respect).
Scott -
Or time compresses by removing fields. I didn't even go into that aspect of it (that more often than not the video isn't just speeded up) because undoing time compression by someone that can't figure out how it was done in the first place is useless because more often than not he'll get it wrong.
If he wants to provide a short 10-second sample of something, we could offer more informed advice. -
I use the AVISynth AssumeFPS(24) (or 23.976 if for DVD) and slow the audio to match.
[MPC-HC] Increasing/Decreasing playback speed causes choppy video
By Zee530 in forum Software PlayingReplies: 6Last Post: 16th Jul 2019, 10:57 -
how to fix cine 8mm playback speed
By hdfills in forum Video ConversionReplies: 11Last Post: 20th Aug 2017, 11:52 -
How to speed up a .MKV to match YouTube Speed?
By NukeyDoo in forum Video ConversionReplies: 2Last Post: 27th Jul 2017, 04:03 -
Change playback speed in Handbrake
By EM1 in forum Newbie / General discussionsReplies: 0Last Post: 12th Dec 2015, 03:27 -
avidemux playback speed
By ricmetal in forum Newbie / General discussionsReplies: 8Last Post: 3rd Aug 2015, 10:47
