I am trying to convert video to avi and every time I do the current software (ANY SOFT CONVEER) the result is that the video comes out fuzzy / out of focus can anyone suggest a program that will conver to avi without loss of quality?
	Why did you choose the AVI container format? It is not so tolerant like the MKV. What are your source files? Which compressor do you use? For H264 compressor, the best solution for lossless cut/trimm videos is Smart Cutter https://www.fame-ring.com/smart_cutter.html
 If you want to simply change the container format to avi in a losssless quality way, I suggest Hybrid or Xmedia Recode, but non of them were created for video editing.Last edited by Abdler; 21st Nov 2019 at 13:59.
	I am kinda a beginner, but the AVI is what was suggested, and also acceptable in Movie make.
 Not sue if MKV is accepted at this time, maybe another Video movie editor/creator.
 I am looking for two items:
 1- need to download in high quality some Christmas video
 2- need to convert these videos in movie Maker to create 1 long presentation
 The YouTube videos are Vevo, and the quality there is 100% good.
 So far in the conversion pgms. I have, the end video is out of focus
 Please help and advise if you are able.
 Rick
 So I need to down load from Utube then convert these to an acceptable version for Movie Maker
 2 Rick
  Hardware decidion for VHS converBy azimoert in forum Video ConversionReplies: 6Last Post: 15th May 2017, 10:57
  Windows10: how to swith on the "Hight Performance" option in Power Options?By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2016, 16:17
  A 23.98FPS video rendered in 29.97 retains the same runtime, why?By skribby in forum Newbie / General discussionsReplies: 7Last Post: 29th Sep 2016, 11:37
  Improve blurry low quality video into clear high quality video.By Osram123 in forum Video ConversionReplies: 2Last Post: 4th Apr 2016, 02:48
  I need help, I want to know avidemux conver 1080 to 720 command lineBy nooblearning in forum Video ConversionReplies: 9Last Post: 15th Feb 2015, 17:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
