Hi all,
I am trying to burn a ISO image for a DVD for a friend. I have 3 subtitle tracks (2 languages + one track for the deaf or hard-of-hearing). If I use DVDStyler to import the video and add the 3 tracks separately, the quality of the subtitles is very bad (low-resolution).
I was able to follow some tips from this forum to get good results, by using MKVToolNixGUI to combine the video and the subtitles before importing the resulting .mkv video on DVDStyler. The quality is ok but still not perfect.
Do you have any other solutions to get even better results?
(I have a PC - Windows 10)
DVD subs are low res graphics without any antialiasing. You'll never get high quality subs with them.
As compared to what?
It's possible to use one of the four colors available for DVD subtitles to provide decent antialiasing. I use it every time and that's one of the advantages of using MaestroSBT for the job of creating DVD subtitles.
I don't use DVDStyler and have no idea how it creates its subs or what might be wrong with the subs it creates. Apparently, pitas is unhappy with the subs he creates using DVDStyler. And I think he probably compares them with subs on retail DVDs and finds his wanting. -
I agree with manono on this. 4 color used judiciously can give quite reasonable antialiasing. Just have to use the right tools.
Scott -
I know you and antialias (a bit) when you create the subs. But the DVD player itself will not antialias. And the subs are rendered at the low DVD resolution (in this day of 2K and 4K video and displays) before being upscaled for display. So they're low quality compared to SRT (or other text based) subs that can be rendered with antialiasing at upscaled resolutions. So if the guy is used to watching SRT subs on an HD monitor he's going to perceive DVD subs as low quality.
I have a hard enough time reading subs, so quick ... I don't admire the visual quality.
ASS/SSA are nice, but I have to embed those into the video anyway, nothing ever plays them 100% correctly, if at all.Want my help? Ask here! (not via PM!)
Thanks for your answers!
I'll try to give MaestroSBT a try then. I'll let you know if I get better results.
From what I read I know I won't get perfect subtitles on a DVD, but I would still try to get at least better results that what I have at the moment.
(Also maybe I should try and play a bit more with the color palette on DVDStyler.)
MKVMERGE Batch Muxing multiple audio and subtitle tracks?
By jahob000 in forum Newbie / General discussionsReplies: 38Last Post: 30th May 2023, 19:13 -
Adding Subtitle tracks to existing DVD and BD ISOs
By solkap in forum Newbie / General discussionsReplies: 11Last Post: 7th Dec 2018, 21:54 -
Potplayer bug with multiple subtitle tracks?
By Acccent in forum Software PlayingReplies: 0Last Post: 13th Dec 2017, 08:00 -
DVD to .mkv/.mp4 w/ all Audio and subtitle tracks
By liquid65 in forum DVD RippingReplies: 2Last Post: 30th Aug 2015, 07:45 -
Recommended bit and sample rates for very high,high,medium and low quality
By alexander121 in forum AudioReplies: 0Last Post: 16th Jun 2015, 11:38
