I have a system that allows me a few options when setting up encoding. They currently won't help us with H265 because they are not ready to support it. I have installed ffmpeg with the h265 library already and I see the option for codec: hevc now. Can someone help me with the flags I should pass to ffmpeg?
We want the highest quality visually first. Our outputs with H264 are around 4GB but I will worry about the size after I see the quality.
My options currently are:
Video Pixel Format: yuv420p
Additional Flags: -f mp4 -vprofile baseline
Thank you in advance.
In general, for the first steps, trust the generic exposed parameters of libx265: "preset" to control the balance between compression speed and efforts, and "crf" to control the quality loss threshold. Visually transparent quality can be achieved for CRF values below about 20; 15..18 is a quite common range for high demands.
I would not recommend to use "-vprofile baseline" (except you are absolutely sure your playback device does not support any more advanced profile).
A "budget" Nvidia card for H265 hardware encoding
By agatek in forum Video ConversionReplies: 37Last Post: 16th Oct 2019, 07:12 -
Worth re-encoding in H265?
By stonesfan99 in forum Video ConversionReplies: 7Last Post: 8th Jun 2019, 03:42 -
AMD Polaris (Radeon RX 4xx) H265 Encoding Samples
By Roph in forum Video ConversionReplies: 156Last Post: 27th Jul 2017, 19:32 -
Mediacoder x265/h265/HEVEC Nvenec encoding.
By crashburn162 in forum Video ConversionReplies: 4Last Post: 29th Nov 2016, 04:07 -
H265 encoding on Solaris
By tola5 in forum Video ConversionReplies: 3Last Post: 8th Feb 2015, 20:29
