Good afternoon, my case I think is even more strange. The operating system is windows 10 home 64 bits
The Shrink DVD had always worked for me until a week ago when I analyzed the DVD well, but did not play the video and if the sound ???. I have reinstalled several times the previous registry cleaning program and it continues in them. I have reinstalled a copy of the operating system and neither. Has the same thing happened to someone? Anyone think of a solution? Thank you !.
nest007
Thank you but it is not exactly the same. The closest is DVDFab.
But what I would like to solve is the problem presented by the DVD Shrink.
Regards -
dvdshrink cannot handle newer copy protections, you need to use
an up to date program such as dvdfab
you might try running dvdshrink in the windows compatibility mode - https://www.lifewire.com/run-older-programs-with-windows-10-compatibility-mode-4587064 -
Thank you,
Tested on another computer with the same operating system works.
Tested with compatibility in previous versions of windows and remains the same, with the same defect
DVD Shrink not working in Windows 10 :( Best free and easy alternative?
By AndreWilley in forum DVD RippingReplies: 28Last Post: 27th Oct 2023, 20:48 -
Windows 10 Updates "Broke" DVD Shrink And Other Programs on PC
By devilcoelhodog in forum ComputerReplies: 21Last Post: 1st Aug 2018, 13:29 -
Is DVD Shrink compatible with Windows 7?
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2018, 07:38 -
dvd shrink and windows 10
By natty in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2016, 10:44 -
ripping BD for windows home server media sharing
By flensr in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2015, 02:31
