    Nov 2019
    germany
    i want to know the fileposition and their formats of
    film time-length with frames
    width,height of the pic
    of mpg2,mp4,avi,mov
    is there a type to identify mp4,mpg2,avi,mov?
  2. Member NiGHT-WiNG's Avatar
    May 2015
    Some sort of cave with bats flying around
    just use MediaInfo as it can give you all that info which you are asking for.
    Nov 2019
    germany
    but i want to know the fileposition
  4. Member NiGHT-WiNG's Avatar
    May 2015
    Do you mean the whole filesize ? if so then mediainfo tells you that as well.
    Nov 2019
    germany
    the position in the mp4-file of the width of the pic
  6. batch file:
    ffprobe -print_format json -show_frames %1 > %1.txt 2>&1
    Sample output:
        "frames": [
                "media_type": "video",
                "stream_index": 0,
                "key_frame": 1,
                "pkt_dts": 160160,
                "pkt_dts_time": "0.133467",
                "best_effort_timestamp": 160160,
                "best_effort_timestamp_time": "0.133467",
                "pkt_duration": 60060,
                "pkt_duration_time": "0.050050",
                "pkt_pos": "0",
                "pkt_size": "101664",
                "width": 720,
                "height": 480,
                "pix_fmt": "yuv420p",
                "sample_aspect_ratio": "8:9",
                "pict_type": "I",
                "coded_picture_number": 0,
                "display_picture_number": 0,
                "interlaced_frame": 0,
                "top_field_first": 0,
                "repeat_pict": 1,
                "side_data_list": [
                        "side_data_type": "GOP timecode",
                        "timecode": "01:07:45:11"
                "stream_index": 0,
                "key_frame": 0,
                "pkt_pts": 220220,
                "pkt_pts_time": "0.183517",
                "pkt_dts": 220220,
                "pkt_dts_time": "0.183517",
                "best_effort_timestamp": 220220,
                "best_effort_timestamp_time": "0.183517",
                "pkt_duration": 40040,
                "pkt_duration_time": "0.033367",
                "pkt_pos": "178621",
                "pkt_size": "20555",
                "width": 720,
                "height": 480,
                "pict_type": "B",
                "coded_picture_number": 2,
                "top_field_first": 1,
                "repeat_pict": 0
