  1. Hello everyone. I have this problem below. I reckon it usually occurs on x264 and x265 videos. It looks like stairs top to bottom as you can see. What is the reason of that and how can I fix it? Any help will be appreciated. Thank you!
    [Attachment 50890 - Click to enlarge]
    [Attachment 50891 - Click to enlarge]
  2. Is it OK with other players, like VLC, MPC-BE?
    Try to click the SW/HW button - or/and another renderer, external, or/and reset settings, backup first, if needed.
    Anyway, this is really strange.
  3. Originally Posted by Dreamer View Post
    I have tried with KM player and GOM player. It not okay with KM but it is okay with GOM. That is really weird.
    What do you mean with the SW/HW button? And, how can I try another rendered or external? Could you please help me more because I don't have enough information about it.
  4. First try to reset settings, Preferences > Reset button (bottom-left corner).
    HW/SW button should be on the bottom navigation bar - next to time.
    Testing alternative renderers or even external renderers is not easy and it should work by default, so...
    Anyway, if it's broken only in PotPlayer and KM player - both players are from the same author, try the official forum, or send the sample or link to file directly to author - homepage > scroll down > link "CONTACT US" (it's email).
    https://potplayer.daum.net/
    https://potplayer.daum.net/forum/
  5. Originally Posted by Dreamer View Post
    I have just tried to reset settings and HW/SW button: didn't work
    Then I went for testing alternative renderers, it was already chosen on "Choose automatically (suggested) -I suppose it is Madshi video renderer- and I tried all of them only "Resident openGL" worked and it has been fixed. So my questions is which video renderer is the best, which one i should choose and why this problem happens when i choose others?
  6. Just try the official forum, or contact the author directly via email. I don't know where is the problem, I'm just a normal user and I can't reproduce the problem.
  7. Originally Posted by Dreamer View Post
    Like i said i already fix the problem. I also sent them a mail they replied that the problem might on VGA but there is no such a thing.
    So my questions is which video renderer is the best to you, which one do you use normally?
  8. Diff renderers depending on what hardware setup you have...best is RELATIVE TO WHAT YOU HAVE
    Like for many EVR works best
    MAD VR would work if you have a good discrete video GPU
