Hello. I do structure Blu-ray discs with BD Rebuilder, v0.50.05, later I create image file from files/folders - ISO with ImgBurn and record movie on Blu-ray disc with ImgBurn. My recorded Blu-ray discs are loop playback - at the end of the recording automatically play again in a stationary blu-ray player. Movies on blu-ray discs I have recorded as a disc image ISO in ImgBurn. I know playback disc it is a reason incorrect structure in BD Rebuilder.
Is there any setting in BD Rebuilder, v0.50.05 that is responsible for this?
I have set up the player correctly - Auto Play: Off, Disc Resume: Off.
DVD movies don't do in BD Rebuilder plays me correctly - when finished, they don't play automatically again.
Samsung SE-506AB - BDXL drive - Hi-Speed USB Series
My BD Rebuilder, v0.50.05 settings:
https://s6.ifotos.pl/img/1-BD-Rebu_qahnaaq.jpg
https://s6.ifotos.pl/img/2-BD-Rebu_qahnaqp.jpg
https://s6.ifotos.pl/img/3-BD-Rebu_qahnaqx.jpg
https://s6.ifotos.pl/img/4-BD-Rebu_qahnaqn.jpg
https://s6.ifotos.pl/img/5-BD-Rebu_qahnaqw.jpg
https://s6.ifotos.pl/img/6-BD-Rebu_qahnaqs.jpg
https://s6.ifotos.pl/img/7-BD-Rebu_qahnaqa.jpg
The way I create ISO with ImgBurn:
a) Create image file from files/folders
b) Source - Add folder - mark BDMV - select a folder
Source - Add folder - mark CERTIFICATE - select a folder
c) Options - Data Type: MODE1/2048, File System: UDF, UDF Version: 2.50, v Recurse Subdirectories (I have marked only this)
d) Information - I click Calculate
e) I click Build (in the bottom left)
f) I choose where to save - Save as type: ISO Files (*.iso) - Save
Recording ISO with ImgBurn:
a) Write image file to disc
b) Source - Add folder - I choose a previously saved file - .iso
c) Destination - I choose: TSST corp BDDV DW SE-506AB
d) Write Speed: 2x
e) Number of copies: 1
f) Save (icon in the bottom left)
I wouldn't know.
I don't think either that IMGBurn comes into play for the matter. I think it's in the authoring.
For blu-ray structures that would contain one movie-only, there is a small tool (if you're not familiar with BDEdit) that can let you dis- or enable "Repeat Playback". Beware though, that you also must set the default audio- and subtitletrack to be played.
I don't use my BD-player very often as I do almost everything via NFS server. I do confirm that this works on my mediaplayers, but a stand-alone BD-player is another thing. The tool is not really user-friendly for choosing your audio- and subtitle track as I don't think it reads the loaded BDMV directory. All'n'all, I would advice you to try it out on a "working copy" of your folder structure, and for burning I would use a rewritable disc for testing it in your player.
Again: this tool is for "movie-only" folder structures!
You can find it here: https://forum.doom9.org/showthread.php?t=146412&highlight=bdedit -
From HIDDENOPTS
MOVIE_ONLY_LOOP=n n = 0/1 - If set to "1" (default), movie-only discs will automatically restart at end-of-play -
Its a text file in the BD_Rebuilder folder
The entries go in your configuration file (*.ini)
You might want to post at Doom9 in the BD_Rebuilder thread -
(nope)
How can I get replacement blu ray discs?
By BirdDaddie in forum Newbie / General discussionsReplies: 10Last Post: 13th Dec 2017, 11:37 -
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 07:32 -
Where do you store your cd/dvd/blu-ray discs?
By johns0 in forum PollsReplies: 17Last Post: 14th Oct 2016, 02:47 -
Anyone using BD XL 100GB Blu-ray discs?
By redwudz in forum MediaReplies: 0Last Post: 19th Aug 2016, 06:57 -
LG blu-ray player is stopping playing blu-ray discs
By mausinho in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Feb 2016, 08:55
