using a dvc100 capture card from a units vhs player
he picture is highly interlaced
I have rides so many combination of the add ones deinterlace but nothing appears top change no matter what combination I select
what am I doing incorrectly
Don't resize vertically before deinterlacing. As a quick test add only the Bob Doubler filter. Watch the output pane in VirtualDub as you step through the video with the right/left arrows on the keyboard.
And just in case: do you know VirtualDub has two display panes? One for the video before filtering, one for after filtering. Make sure you have the output pane enabled and are viewing it.
Problem Saving .AVI Clip In Virtualdub
By todsweeney in forum Newbie / General discussionsReplies: 5Last Post: 26th Oct 2018, 04:33 -
VirtualDub and .Vob file problem
By JapaneseIdolWota in forum Video ConversionReplies: 35Last Post: 20th Aug 2016, 03:53 -
Problem with merging AVI files using VirtualDub
By rocknrolla115 in forum EditingReplies: 2Last Post: 9th Apr 2016, 17:19 -
H264 conversion problem Virtualdub
By Shadowofthedarkgod in forum Video ConversionReplies: 11Last Post: 8th Nov 2015, 13:42 -
Problem with External Encoders in VirtualDub
By XenonS in forum Video ConversionReplies: 6Last Post: 28th Oct 2015, 09:19
