Im trying to blur a hardcoded subtitle on a movie, but keep getting this error each time and cant understand what it means, or how to fix it
Code:Argument '(2019)' provided as input filename, but 'C:\ffmpeg-3.4-win64-static\bin\Joker' was already specified.
				Results 1 to 10 of 10
	Post the complete command-line and log. What OS/shell? Are you working on the terminal or via a batch file?
 To me it points to some error with e.g. forgotten (or too many) quotes around a filename that has spaces or some error due to not escaped characters.
 Hi firstly many thanks for replying back to me, its most appreciated. But the movie says joker (2019) so I removed the (2019) but still get same error just cant understand why I get that
 this is what dimensions I have
 delogo=x=332:y=506:w=606:h=130
 "Are you OK with above delogo filter parameters"
 Press Y for Yes to preview, N for No and return to start. [Y,N]?Y
 Argument '.mkv' provided as input filename, but 'C:\ffmpeg-3.4-win64-static\bin\Joker' was already specified.
 "Start ffmpeg with delogo filter parameters?"
 Press Y for Yes to continue, N for No and return to start. [Y,N]?
 I am on windows 10 I dont understand the rest you saidshell? Are you working on the terminal or via a batch file?
	Do you mean the complete script
 @setlocal
 @echo off
 @echo "delogo parameters script with report active"
 @set xx="Unknown"
 @set yy="Unknown"
 @set ww="Unknown"
 @set hh="Unknown"
 @rem folder where ffmpeg.exe is located
 @set FF=C:\ffmpeg-3.4-win64-static\bin
 @set PATH=%FF%;%PATH%
 @set filename=%~1
 @rem video quality settings
 @set vq=25
 @rem audio bitrate
 @set ab=192
 :new
 @cls
 @echo .
 @echo .
 @echo Old delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh%
 @echo .
 @echo .
 @rem delogo filter settings
 @set /p xx="Enter X - the top left corner coordinate of the subtitle: "
 @set /p yy="Enter Y - the top left corner coordinate of the subtitle: "
 @set /p ww="Enter W - the width of the subtitle to clear: "
 @set /p hh="Enter H - the height of the subtitle to clear: "
 @cls
 @echo .
 @echo .
 @echo delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh%
 @echo .
 @echo .
 @echo "Are you OK with above delogo filter parameters"
 @choice /c:yn /M "Press Y for Yes to preview, N for No and return to start."
 @if errorlevel 2 goto new
 @if errorlevel 1 goto start
 :start
 @ffplay.exe -hide_banner -v 32 -stats -autoexit -i %filename% -an -vf "setpts=PTS/5,delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh%:show=1"
 @echo .
 @echo .
 @echo "Start ffmpeg with delogo filter parameters?"
 @echo .
 @echo .
 @choice /c:yn /M "Press Y for Yes to continue, N for No and return to start."
 @if errorlevel 1 goto selenc
 :selenc
 @echo .
 @echo .
 @echo "Please select encoder - Slow but higher qaulity press Yes or Fast but lower quality No"
 @echo .
 @echo .
 @choice /c:sf /M "Press S for SLOW or F for FAST encoder"
 @if errorlevel 2 goto ffast
 @if errorlevel 1 goto sslow
 :sslow
 @cls
 @echo .
 @echo "ffmpeg libx264 begin encode with delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh% parameters"
 @echo .
 @SET x264opts="crf=%vq%:level=4.0:qpmin=8:vbv_maxrate=2 0000:vbv_bufsize=10000:ref=3:bframes=3:rc-lookahead=32:cabac=1:interlaced=0:no_psnr=1:no_ssi m=1:bluray_compat=1:open-gop=0:pic_struct=1:aud=1:nal_hrd=vbr:force_cfr=1:o verscan=show:colorprim=bt709:transfer=bt709:colorm atrix=bt709"
 @set aproc="pan=stereo|FL < FL+1.414FC+0.5BL+0.5SL+0.25LFE|FR < FR+1.414FC+0.5BR+0.5SR+0.25LFE,dynaudnorm=p=1/sqrt(2):m=100:s=20"
 @set vproc="pp=ac,delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh%,sc ale=iw:ih:sws_flags=spline+accurate_rnd+full_chrom a_int+full_chroma_inp:interl=-1:out_range=auto:out_color_matrix=bt709,format=pix _fmts=yuv420p"
 @ffmpeg.exe -hide_banner -report -v 32 -stats -y -i "%filename%" -vf %vproc% -c:v libx264 -preset faster -tune film -profile:v high -level:v 4.0 -x264opts %x264opts% -x264-params %x264opts% -af %aproc% -c:a ac3 -b:a %ab%k -f matroska "%~n1_delogodynaudio.mkv"
 goto end
 :ffast
 @cls
 @echo .
 @echo "ffmpeg NVEnc begin encode with delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh% parameters"
 @echo .
 @ffmpeg.exe -hide_banner -report -v 32 -stats -y -i "%filename%" -vf %vproc% -c:v h264_nvenc -level:v 4.0 -preset:v hq -profile:v high -cq %vq% -qmin:v 8 -qmax:v 29 -bufsize:v 10000k -maxrate:v 20000k -g 250 -bf 3 -refs:v 3 -rc:v vbr_hq -rc-lookahead 32 -b_adapt 1 -temporal-aq 1 -spatial-aq 1 -i_qfactor 0.75 -b_qfactor 1.1 -coder:v cabac -bluray-compat 1 -aud 1 -aq-strength 8 -af %aproc% -c:a ac3 -b:a %ab%k "%~n1_delogdaudnv.mkv"
 goto end
 :end
 @echo terminating script
 @endlocal
 @timeout 30
 @exit /b
	I'm not sure (you didn't post the complete log) but maybe the missing quotes around %filename% in this line are the problem:
 I.e. try changing to:Code:@ffplay.exe -hide_banner -v 32 -stats -autoexit -i %filename% -an -vf "setpts=PTS/5,delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh%:show=1"
 Code:@ffplay.exe -hide_banner -v 32 -stats -autoexit -i "%filename%" -an -vf "setpts=PTS/5,delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh%:show=1"
	Hi I didnt post log as it was far too big, But I can see you have edited that line to have quotes "" around "%filename%" I just tried movie again, and no error plus it showed a green oblong around subs, so it seems you have fixed problem many thanks for that. But I just find it very strange why on some movies it dont do it
	orCode:@set filename="%~1"
 might just work fine, that second example I'm not sure, it was a while already ...Code:@set "filename=%~1"
 If I remember correctly, if there is %1 in batch script, quotes are added if necessary - if there are gaps in the string.
 To manually override that quote adding feature, because sometimes it might actually break the code, you use "%~1" for path strings
 Because %~1 turns that automatic quote adding feature off.
 Using batch scrips I always controlled that manually, just to be sure. So I used %~1 or %~2 etc, and added quotes if that variable was a path string or if it mattered in the code.
  FFmpeg setdar errorBy Megafox in forum Newbie / General discussionsReplies: 3Last Post: 11th Feb 2018, 10:10
  Just another ffmpeg fontconfig errorBy ks.zealot in forum Video ConversionReplies: 6Last Post: 30th Apr 2017, 11:59
  ffmpeg error setting profileBy yukukuhi in forum Video ConversionReplies: 24Last Post: 10th Jul 2016, 00:51
  need help with ffmpeg error messageBy mulliganman in forum Video Streaming DownloadingReplies: 0Last Post: 9th Feb 2016, 17:33
  FFmpeg resize and crop errorBy z-machine95 in forum Video ConversionReplies: 4Last Post: 23rd May 2015, 19:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
