Hello everyone
Thank you for receiving me in your forum. Sorry if this post is not well located. I'm using the google translator, sorry if I don't understand well.
I have been digitizing my VHS with the EasyCap USB capturer and the Honestech VHS to DVD 8.0 Deluxe software for a year. Every few minutes the video freezes, the audio does not. I think it's because of the EasyCap since I have a PC fast enough for VHS:
AMD FX 6300
16gb1600mhz RAM
Geforce GTX 950 2gb
Windows 7 Ultimate 64bit
My uncles have DV, they want me to pass them to DVD so I think about maybe getting a captor for it, but I prioritize the quality for my VHS.
So I want to buy a new USB capturer and my options are:
1. Pinnacle 700
2. Pinnacle 710
3. Dazzle Video Creator Plus HD
4. Dazzle DVD Recorder Plus
5. Pinnacle Liquid Edition 7 AVID
6. Pinnacle Moviebox Dv
7. Pinnacle Moviebox DV (other version)
What do you recomend me?
Also, a friend will give me the Hauppauge Win-tv Pvr-150 Multi Pal 26559 (c110). It's good, can I use it? With what software?
Thank you very much for your time!
Fernando
Buenos Aires, Argentina.
Results 1 to 1 of 1
Adding a new External Capture Card to my Hauppauge Colossus Internal Card
By MounaLafi in forum Capturing and VCRReplies: 30Last Post: 21st Feb 2019, 14:40 -
Windows7 end of life, no good all-in-one capture options for 10
By clashradio in forum Capturing and VCRReplies: 21Last Post: 31st Aug 2018, 13:38 -
Can't capture signal from JVC HR-S9911U VHS deck into Hauppage capture card
By vhscapture in forum Capturing and VCRReplies: 3Last Post: 18th Jul 2016, 12:07 -
Is the Canopus ADVC-50 card still an OK capture card?
By Mickey Juice in forum Capturing and VCRReplies: 8Last Post: 21st Feb 2016, 08:34 -
MiniDV capture options / quality of outside video transfer companies
By JonathanL in forum Capturing and VCRReplies: 14Last Post: 17th Mar 2015, 14:24
