Is there a DVD ripper that will not force the video into 720x480 with hard letterbox bars, throwing away vertical resolution? I'm looking for one that will stretch the horizontal resolution to restore the proper aspect ratio, like what DVD players and playing software do. If free playback software can figure out exactly how far over 720 pixels wide to stretch, why can't ripping software that costs $?
I just went through the trials of Leawo, AnyDVD, and Video Solo. All do the same forcing of an anamorphic widescreen DVD into a 720x480 box with hard letterbox bars, and crap quality because they throw away almost half the vertical resolution, and the video plays as a postage stamp in the middle of a widescreen TV, just like a hard letterboxed DVD.
Ideally I'd like to have the same software rip Blu-Ray.
Results 1 to 11 of 11
Boy is that post full of misconceptions.
Ripping means to put the DVD on the drive with the encryption removed. 720x480. What you want to do is to convert or reencode after having gotten the DVD onto the hard drive.
Since it's stored on the DVD as 720x480, how can any resolution be lost after being ripped. And after resizing it how you like, no vertical detail will be gained. It might have a larger vertical resolution, though. Either you're using the wrong programs for the job, or you don't know what you're doing.throwing away vertical resolution?
It was no longer a DVD, I take it? Then when making your MKV or MP4 or whatever you should have set a SAR to have it resized during playback or (probably better in your case) have the black bars cropped away and the whole video resized. Rippers don't do that; reencoders or converters do. davexnet suggested one and there are dozens more....and the video plays as a postage stamp in the middle of a widescreen TV -
When an anamorphic DVD is played, the DVD player or DVD playing software *stretches* the HORIZONTAL resolution, according to the VOB file attributes for the Pixel Aspect Ratio.
What DVD rippers do when converting to other formats is they *reduce* the VERTICAL resolution in order to get the Display Aspect Ratio that matches the Pixel Aspect Ratio, while *constraining* the HORIZONTAL resolution to 720 pixels.
Thus VERTICAL resolution is lost in the conversion. Ripping and converting software should never throw away any of the 480 (or 576) lines of an anamorphic encoded DVD, yet that's what they do.
DVDfab can be set to higher resolutions and what you'll get is a converted video that's 480 pixels high, with whatever hard letterbox bars are in those 480 lines, with a correct wider than 720 pixel stretch. But after successfully getting it to rip one anamorphic DVD properly, it sets itself back to 720x480 + hard letterbox for the next one.
The problem is this should be the *default method* on all DVD rippers but it's not. Without having to fiddle with setting *for every DVD* you'll get your anamorphic DVD rips crammed into a 720x480 box with hard letterbox bars added, or increased in size if the original already had some to conform to a 16:9 display when stretched out to fit.
So when I have a ripper convert an anamorphic DVD to x265 MKV I'd like it to make the output 864 (or whatever the DAR settings say it should be) by 480 *without having to fiddle with settings for every disc*.
Think of how inconvenient it would be if you had to go into a DVD player's menu *for every disc* to set the machine to widescreen? Would you be happy with every widescreen DVD being displayed in "postage stamp mode" until you re-set it to widescreen? That's what DVD ripping software does. -
Maybe some do. Most people, though, have no problems at all cropping away the black bars and then resizing to ... say ... 1152x480, the 2.40:1 ratio that's very common. No vertical reduction there. Sure, if you want a 720 width you might lose some vertical resolution, but it's certainly not necessary. Again, you're either using the wrong tools for the job, or you're using them incorrectly.
But didn't you originally say the DVDs were letterboxed? If so, the effective vertical resolution could be significantly less than 480.Ripping and converting software should never throw away any of the 480 (or 576) lines of an anamorphic encoded DVD, yet that's what they do.
Nonsense. Films come in all kinds of aspect ratios. What's to say your next one might not be in a different aspect ratio than the previous one?The problem is this should be the *default method* on all DVD rippers but it's not.
No, that might be what your encoders do. Why not try davexnet's suggestion?That's what DVD ripping software does.Last edited by manono; 11th Nov 2019 at 15:56.
The consensus on this forum was established (not outside of this forum necessary) , to understand each other that ripping means to just remove protection and converting means encoding that unprotected footage to other video, format.
AnyDVD is just ripping tool (does not convert), so your assumption that AnyDVD does something to video is not right.
Other tools do both, they rip content and then convert. Like DVDFab. -
To keep bizzybody and those who may read this on the right track, ripping doesn't mean "...just remove protection...". manono and _Al_, you know better than to state that.
Some programs like DVDDecrypter allow you to rip a DVD and retain the protection.
As I've posted dozens of time, ripping an optical disc means making extracting the EXACT BIT FOR BIT DATA from the disc to another storage device (HDD, SSD, flash drive, etc). Always meant that, always will in correct usage. I wish I could find who originally posted this, but saying "I'm going to rip into a smaller .mp4, .mkv, .avi, etc." makes as much sense as "I'm going to rip me a sandwich".
I've never understood DAR, SAR, PAR, but there are only four (two for NTSC and two for PAL) resolutions that a DVD (and a rip) can be:
From "What is DVD?" on this site: https://www.videohelp.com/dvd
NTSC (NTSC Film)
Video:
Up to 9.8 Mbit/s* (9800 Kbit/s*) MPEG2 video
Up to 1.856 Mbit/s (1856 Kbit/s) MPEG1 video
720 x 480 pixels MPEG2 (Called Full-D1)
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
29,97 fps*
23,976 fps with 3:2 pulldown = 29,97 playback fps (NTSC Film, this is only supported by MPEG2 video)
16:9 Anamorphic (only supported by 720x480)
PAL
Video:
720 x 576 pixels MPEG2 (Called Full-D1)
704 x 576 pixels MPEG2
352 x 576 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
352 x 288 pixels MPEG2
352 x 288 pixels MPEG1 (Same as the VCD Standard)
25 fps*
16:9 Anamorphic (only supported by 720x576) -
If all you want is to put a DVD on the hard drive retaining any possible protection, then there's no need for DVDDecrypter to begin with. From the DVDDecrypter page here:
And that's what it's used for. Yes, it has other uses, such as demuxing, decrypting by chapters, etc. The definition of "Rip" as defined in the DVDHelp glossary:DVD Decrypter was one of the best DVDDecrypter tool, it enables you to decrypt and copy DVDs to your HD.
No conversion or reencoding as bizzybody seems to think. And as for "bit-for-bit", that's understood. Pure decrypters such as DVDDecrypter are incapable of doing anything with the data besides removing the protection and putting that data on the hard drive. Notice the definition uses quotation marks when referring to ripping to MP3, but none when ripping to VOBs. The quotation marks tell me that while the word might sometimes be used in that sense, technically it's wrong.To take off the audio or video from a CD or DVD. Often CD Audio is "ripped" to MP3 files or DVD video ripped to VOB files.
Our point exactly. All you've managed to do is muddy the waters.... but saying "I'm going to rip into a smaller .mp4, .mkv, .avi, etc." makes as much sense as "I'm going to rip me a sandwich".
_Al_ in his previous post laid to rest the notion that AnyDVD should be expected to do something besides decrypting to the hard drive. -
Sorry if I'm muddying the waters even more and getting off topic, but I know I can copy the contents of an unprotected DVD to my hard drive (I still use AnyDVD or DVDDecrypter just in case) and can play it directly from there (either through the .ifo or .vobs). But if it's a protected disc, I can't do anything with the copied files, even running them through a decrypter like DVDDecrypter or MakeMKV correct? Sorry, I don't have any protected DVDs handy to experiment as my collection is almost all Asian movies with no protection.
I do remember experimenting way back when, copying the .cda(s) from a CD and not being able to play them. -
I've used DVDFab and makeMKV to rip some DVD's (that never existed in Blu-ray) to hard drive, some were full screen some were anamorphic (meaning non square pixel) and I never had any problems with the aspect ratio whether I chose full disc or just main movie, I have a feeling that the OP had some DVD's that are hard letterboxed and he thinks that was resulted during ripping.
Oh, right. When I wrote my previous answer I wasn't thinking of using DVDDecrypter on unprotected DVDs. I use it for that as well, as I work with DVDs from a country that doesn't apply any copy protection.
If you play copy protected VOBs that are on the hard drive, they play ugly, all broken up into blocks. If you happen to have a copy protected DVD on the hard drive and want to remove the protection, you create an ISO from it and mount it in a program that creates a virtual drive so that DVDDecrypter thinks you have a DVD in an optical drive and then you can easily decrypt it. One such program is ImgDrive, but there are several.
WinX DVD Ripper?
By adrien23 in forum DVD RippingReplies: 8Last Post: 1st Nov 2020, 07:04 -
Cropping an anamorphic DVD: what aspect ratio settings now?
By ItaloFan in forum Newbie / General discussionsReplies: 19Last Post: 31st Aug 2019, 16:41 -
Magic DVD ripper
By DaneClark in forum DVD RippingReplies: 1Last Post: 15th Jun 2016, 18:35 -
DVD with 4:3 material - need for anamorphic?
By pooksahib in forum Video ConversionReplies: 16Last Post: 1st Apr 2016, 04:16 -
WinX Dvd ripper Q
By Syrinx in forum DVD RippingReplies: 2Last Post: 16th Oct 2015, 16:25
