Results 1 to 13 of 13
  1. hi buddy
    i have issue with only .mp4 files that not shown full length and resolution in windows details pane.
    i install icaros and its perfect for all extensions except mp4 files
    this is example with mkv file that show all property of file:
    http://icecream.me/uploads/a96a7054c04a5fad31e167e70a4b4eea.png
    and its for mp4 file:
    http://icecream.me/uploads/db404f0afdabd31b2ae166b1c8963cdb.png
    how can i fix this problem?
    YES, i know i can use mediainfo. but i need to see properties in details pane windows
  2. Member DB83's Avatar
    Jul 2007
    So did you upload the wrong clip since both refer to a .mp4 file ?
    And since a .mp4 is a container format that Windoze would have you believe does not exist then bite the bullet and use a different program which you already know about.
  3. You need a Shell Extension that provides properties for mp4 files. General info about shell extensions:
    https://docs.microsoft.com/en-us/windows/win32/shell/shell-exts
  4. Originally Posted by DB83 View Post
    sorry. i FIXED.
  5. Originally Posted by jagabo View Post
    i dont know how it works
  6. just search for "shell extension mp4 properties" or something like that.
    not work
    in my previous windows all things were right. but i dont know what did?
  8. Member DB83's Avatar
    Jul 2007
    I my Win7 I can see certain properties for mp4 such as run time and resolution in the details tab from Windows Explorer >> Properties.
    I still prefer mediainfo since it gives a whole lot more info.
  9. Originally Posted by enable View Post
    You installed a shell extension that provided that information to Windows Explorere so it could display it.
    It looks like Icaros is supposed to supply that for Explorer. Is mp4 in its list of file types?
    Mar 2008
    I'm not sure an extension is even necessary. My Windows 8.1 can display the resolution in details view, you just have to enable
    the right columns.
    no. icaros have all type except mp4
  12. Originally Posted by davexnet View Post
    the right columns.
    in windows sever 2016 everything is ok. my OS is windows server 2012 RC2.
  13. Originally Posted by davexnet View Post
    the right columns.
    Windows 8 and 10 have built in support for MP4. Windows 7 and earlier do not.
