Hi,
I am a real newbie in video editing...
rarely used Windows movie maker for few simple tasks I need sometimes.
I import clip and adding a slide before and then after a clip. I found simple technics for these requirements and used them.
I used Windows MovieMaker on Windows 10. Now I have a new build on new computer and cannot find the source of old MM.
I downloaded Windows 10 movie maker, but cannot find any way to access the menus, insert the slides. So I feel like first time touching a computer.
On this web site I found a link to old movie maker (2012). Sorry for naïve question. Is it guaranteed to be safe or site owners are not responsible for the content for download?
And other question is MovieMaker 10 is not less capable than old one. May be I don't see options because of not paid version downloaded from MS Store?
Or the basic things I mentioned are doable in free version.
If yes please tell how to access menus for inserting slides.
Thanks.
Although sometimes rather old software available for download at VideoHelp does work correctly on newer versions of Windows, there is no guarantee this will be true in every case. However, software downloaded from VideoHelp should not contain any malware.
VideoHelp's owner checks software with VirusTotal before making the download available from VideoHelp itself. (VirusTotal is a website which, as described by Wikipedia, "aggregates many antivirus products and online scan engines to check for viruses that the user's own antivirus may have missed, or to verify against any false positives")Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thank you very much for explanation.
Could somebody answer about Windows 10 Movie Maker.
Does it actually includes all the features old one had?
How to access menus?
Or there is big limitation between paid and free versions? -
The classic Windows Movie Maker is free, always was.
I think the feature list remained the same.
You can expand some features with a variety of plugins, free and paid. -
I am asking about Movie Maker 10 - Tell your story
[Attachment 50833 - Click to enlarge]
By seeing shortcuts it looks like it has not less features than the previous. The question I cannot figure out where are menus.
Probably simple but I am missing something.
I need to insert slides in the clip for example and don't see any option for that. -
aahhh … I just tried to click on trim tool … and it says that this feature is in paid version only. Do you want to purchase?
Sure I say no... for such a basic thing. I just download old ver that I am familiar with. The only thing that it still uses .net3 that is out of support (I mean no security patches).
Finally, not a big deal
Using movie maker . . .
By aviheader in forum Video ConversionReplies: 3Last Post: 14th Aug 2019, 17:37 -
windows movie maker 2.1
By tutorpros in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2017, 14:36 -
Movie Maker 2.6 or Live Movie Maker 2012
By Adithya in forum EditingReplies: 4Last Post: 22nd Mar 2016, 20:25 -
how do i fit 6 hour movie on dvd using windows movie maker
By memphis77 in forum Video ConversionReplies: 8Last Post: 25th Jul 2015, 01:25
