I'm trying to rip a portion of one of my DVDs. I usually use MakeMKV, then extract the mkv to an mpg with gMKVExtractGUI. Then I use DGIndex to index the file.
No matter what I do it's playing too fast. It's a (mostly) film source being sped up to 29.97 fps basically. There's some 30fps animation at the end.
Ripping that segment again with DVD Decryptor and using DGIndex doesn't seem to help.
Video of the problem: vlc is the original file and mpc-hc is the script
https://youtu.be/0ju505omnzc
Here's my script.
When I used TFM().TDecimate(), it was pretty choppy since it was sped up. Using QTGMC is pretty much the same thing but when I run the script in MPC-HC it plays back normal, although the final output is sped up still.Code:SetFilterMTMode("QTGMC", 4) v = MPEG2Source("D:\dvd-blu ray rips\video_ts\HERCULES_SCN\VIDEO_TS\VTS_01_1.d2v") a = FFAudioSource("D:\dvd-blu ray rips\video_ts\HERCULES_SCN\VIDEO_TS\VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.ac3") AudioDub(v,a) Spline64Resize(720,480) Spline64Resize(640,480) Crop(4, 0, -4, -2) x = float(width) / float(height) spline64resize(round(x * 2160.0),2160) Prefetch(12)
I did choose Ignore Pulldown Flags in DGIndex, did that possibly effect anything?
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Just decrypt it with DVDDecrypter or whatever works. and then use DGIndex on the VOBs.
I did choose Ignore Pulldown Flags in DGIndex, did that possibly effect anything? -
Stuttering DVD on fast movement
By akkers in forum Authoring (DVD)Replies: 9Last Post: 4th Apr 2016, 13:04 -
dvd player that plays vcds
By ghola in forum DVD & Blu-ray PlayersReplies: 21Last Post: 17th Mar 2016, 17:24 -
Trying to RIP Anime DVDs to Episodes. Problems with Avisynth Filters.
By weltall in forum DVD RippingReplies: 9Last Post: 8th Mar 2016, 13:07 -
Video exported with pinnacle16 :image plays then freezes audio plays fine
By RonWolpa in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2015, 18:00 -
Avisynth Bob Alterntive which is just as fast
By MrBiggles in forum Video ConversionReplies: 15Last Post: 22nd Jul 2015, 04:49
