Everyone knows you can record anamorphic signal on VHS, it's not w problem.
But were there ever anamorphoc camcorders or lenses for VHS camcroders available?
They were working for them for sure:
https://www.newscientist.com/article/mg12717283-400-technology-widescreen-pictures-wil...on-be-on-tape/
But where is the final product?
I have NV-M9000 was there ever an anamorphic lens produces that would be compatible?
Aug 4 1990, Wow. You've been waiting for 29 years and you haven't given up.
There is a work around if you admire the look of VHS in a widescreen format, Use a cheap modern widescreen camcorder, If you are doing stationary recording feed the HDMI output from the camcorder to a HDMI to composite adapter with the frame squeezed horizontally and record as such on VCR, during playback just set the TV to stretch the frame horizontally and Wala you get widescreen VHS. If shooting mobile just playback the file after shooting in the camcorder and follow the exact same steps above. -
If it fits, then time to save the cash.
I have just dug pu this article minutes ago, I'm not even that old. And I have already outlined my workflow for VHS duplication, Though I can just use a VCR with my DCR-TRV828E using S-video output in widescreen mode, though I suspect my VCR might have widescreen settings. -
That was just a joke. Anyway, I don't know about VHS camcorders but I do record S-VHS in anamorphic format, I set my media player to playback a clean HD video in a horizontally squeezed state in 4/3 format and down convert the resolution to 480i suitable for VHS, then I use an Aja device to convert HDMI SD 480i output from the media player to S-Video analog and record that into my S-VHS deck, At the playback I just set the TV to stretch the frame horizontally and it actually looks better than widescreen DVD, no compression artifacts what so ever.
VHS-C: Adapter or Camcorder?
By Tig_ in forum CapturingReplies: 20Last Post: 11th Jan 2022, 22:44 -
Blue Line on my Panasonic VZ17 VHS-C Camcorder
By JordanGenesis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 17th Mar 2019, 15:37 -
JVC GR-FX17 compact VHS camcorder on screen displays
By VHS-C98 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Jan 2017, 22:18 -
Reuse of a VHS Camcorder
By slauhoff in forum Newbie / General discussionsReplies: 19Last Post: 17th Oct 2016, 13:04 -
How to connect old VHS Camcorder to TV for Playback
By VHS-C98 in forum Newbie / General discussionsReplies: 7Last Post: 13th Dec 2015, 14:45
