Not sure whether this is the best section to post this, or if I would do better taking it to some other users' support site entirely. But I exhausted the scope of what they could suggest to me at a local Apple store, and some of you may have some good answers ?
I have a 12.9" Ipad (Pro ?) that was purchased between 1 and 1.5 years ago. So, it does not have that newer-models' wireless connector underneath one long side. (That looked pretty good, for adding a keyboard they did sell at the Apple store . . . but I'm not going to scrap this Ipad and buy a new one just to get it.) I'd like to find a good, reliable example of the following, which I gather is going to have to be from some third-party manufacturer.
1. A keyboard, preferably not Bluetooth-based. With the exception of the factory hands-free setup my car has for use with a cell-phone, I've found Bluetooth to be flakey, sporadically dropping connections for no apparent reason.
2. A docking station, or alternative means for multiplexing the otherwise very limited In | Out connections, for things like USB devices. They make these things for laptops. Or even basic USB hubs, at least. The problem may be in having good compatibility with the Apple device, for something they don't themselves make or approve.
Results 1 to 19 of 19
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
Thanks for your reply. I need to determine exactly of what Gen my Ipad is, for which finding the invoice or invoice date may provide a clue. But I think it likely predates the Nov. 2018 model (Gen 3), which may rule out the Kanex, or the competing solutions from Satechi or Hyperdrive. Your first link seems to be a proposed product, only.
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
Thanks, Case.
IPAD Pro 12.9 (2nd. gen.)
Model # A1670
Model (Part ?) # MP6G2LL/A
Software ver. 12.3.1
Still would like to find out -- for sure -- whether any of these are going to be compatible:
https://www.frys.com/product/9401331?nearbyStoreName=false&site=frilanding072718
{the most in line with what I was looking for, but I'd still need to get past the sole port
thing . . . }
http://matias.ca/aluminum/backlit/ {but it's Bluetooth, so likely not what I wanted}
http://matias.ca/60/pc/
The keyboards that the Apple stores have now are for a later gen. of hardware, with different
connections.
I inquired at the website for one of those docking station type deals, but did not get a
definitive answer as to the compatibility.
[EDIT: reviews were not so good on the Matias, so now looking for info re the older (wired) Apple
keyboards that were originally intended for i-Mac but which may now only be available as refurbs,
or a Satechi keyboard that required an adapter.]Last edited by Seeker47; 1st Dec 2019 at 17:37.
You iPad has bluetooth. Wireless keyboards are an option.
Apple website lists their own new version wireless keyboards, and the Logitech and Belkin connected keyboard as compatible/fitting this model iPad.
Apple Store - iPad Accessories - Keyboards - iPad Compatibility: iPad Pro 12.9-inch (2nd generation) -
Bluetooth Keyboards usually work with your iPad...Lots of Good reviews on Youtube
If you want a branded one that works , try the logitech oneLast edited by teodz1984; 4th Dec 2019 at 10:17.
the connector you are referring to are smart connect dock.. similar to pogo plugs..newer-models' wireless connector underneath one long side.
https://fortune.com/2016/04/26/logi-base-ipad-pro-charging-dock/
These propriety tech means expensive prices... Since the usually need certification to work with Apple ...Last edited by teodz1984; 4th Dec 2019 at 10:16.
thats the problem with apple.. they keep changing ports to keep sucking up the money of customersThe keyboards that the Apple stores have now are for a later gen. of hardware, with different
connections.
definitive answer as to the compatibility.Last edited by teodz1984; 4th Dec 2019 at 10:16.
Thanks for that link. (And also to teodz1984.)
I took the opportunity of Cyber Monday to order a trio of Satechi solutions, including a wired keyboard and a port expansion doohickey that may have previously been mentioned here. They seemed to have mostly favorable user reviews. Got a nice combo discount on them, now we'll see if they work. If not, there are now some alternatives to explore, thanks to you. I can report back on this in due course.
Do people also use a mouse of some sort with their IPADs ? Not sure of how much value that might be: after all, the IPAD is essentially a tablet. That said, I recall the MicroSoft Surface was trying to have it both ways, as a tablet that could (with the right configuration) stretch itself into being a pseudo-laptop.Last edited by Seeker47; 5th Dec 2019 at 12:11.
Much as MS keeps on arbitrarily renaming and relocating many previously familiar features in Windows -- for no good reason, or maybe just to frustrate us ? But I guess that helps to justify their selling a "new and updated" product that was perfectly fine in its earlier UI incarnation.
Update: I bought this wired keyboard
https://www.amazon.com/Satechi-Aluminum-Keyboard-Numeric-Keypad/dp/B07DRCWHM3/ref=sr_1...s%2C276&sr=8-5
which looks to be of good quality with good features, quite capable, and would be the one I'd like to use. I was hoping to use their docking station that I also got
https://www.amazon.com/Satechi-Aluminum-Adapter-Charging-Headphone/dp/B07K6YFW7X/ref=s...s%2C302&sr=8-5
to connect it, which from the description looked like my 2018 model (2nd. Gen.) Ipad Pro would be on the compatibility list. However, the connector would not connect at all, and I did not want to try to force it to. The connector has the same shape as the native Ipad charger connection, but there seems to be an extra thin metal bar in the middle. A simple male / female connector mismatch ? (I have no familiarity to speak of with the Apple hardware.) I'm leaving messages for Satechi, but have not heard back.
[Re the whole docking station or hub thing, I'm still looking to get those extra device ports, to get around that very limiting solitary connector on the Ipad.]
The Kanex solution appears to be for Gen. 3 and later only. The DoBox Pro that you linked looks promising, but I'm not seeing where it has emerged from that Kickstarter campaign to become a shipping product. Nothing about it on Amazon yet, although there are some other links for this general category, such as
https://www.amazon.com/dp/B07M6R3CPB?ref=dacx_dp_9172981550101_6334097010001&aaxitk=6H...j-MxPL8fqkJGIQ
That one is cheap enough to be a low-risk experiment.Last edited by Seeker47; 22nd May 2020 at 17:03.
Could you be more specific ? Product link ?
It's not Thunderbolt (?), doesn't seem to be any recognizable flavor of USB, despite the published specs.
You wouldn't think this would turn out to be this difficult . . . .
Thus far, I have not been able to correctly identify the connector for my 12.9" Gen 2 Ipad Pro: nothing I have tried so far in my attempt to "multiplex" that damned solo connector (to accommodate a keyboard, flash drive, or etc.) seems to fit, and I would not try to force one in, even if the size appears similar. The Satechi multi-port gizmo did not fit, nor did one from Kanex. Have not been able to get any response from Satechi for comment. The repeated pandemic closures of the Apple stores has not helped, either. I took some photos of the connector, and of the charger plug that came with the Ipad, which of course does fit that connector, and I could post them here. In the meantime, I noticed this item in a Frys weekly email circular
https://www.frys.com/product/9990956
That connector looks to be of the right size, and has the same sort of "hash marks" on it. Maybe a clue ?Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
Well, I may finally have the answer. Stopped by a Best Buy (Yes, they are still in business -- someone just asked me) and spoke to the Apple specialist there. He identified the connector type as 'Lightning', but that this would do me little good. He said that nothing else other than charging -- with the included charger -- would work there, for wired use. That this generation of Ipad (and by extension the later ones too) were designed to be tablets ONLY, and not for taking on anything like the functionality of a general computer or laptop. So you wouldn't be installing a bunch of regular office apps such as you are using on your desktop system; it's mainly just for email, light web browsing, looking over photos, maybe viewing a movie on an airplane flight. Thus spake the Best Buy Apple guy. The dual-usage, "have it both ways" solutions pioneered by Microsoft Surface and that I see being copied by others came later. Had I known that upfront, back in 2017, I might never have taken this detour into Apple-ville. (It may still hold some value for wireless email or web-browsing, like while half-watching a ballgame, but that's about the extent of it.)
It seems that some auxiliary connection might still be possible -- like for a keyboard -- via wireless Bluetooth, but most of my experience with that tech has turned out fairly dismal. Bluetooth has just been flakey, everywhere I've tried to use it except with the hands-free cellphone support in my car.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
I use a logitech k780 bluetooth multi-device keyboard (goes between surfacepro, macbook, ipad & android phone) - daily, constantly, for months on end - and haven't had a single hiccup with using it.
Scott -
Your suggestion prompted me to read through a whole bunch of (mostly 'Verified Purchase') reviews on Amazon, and traversing a few different models. It was looking like the Logitech K375S was recommended over several others. Also, an emerging pattern stating that some of the Logitech products used to be a lot better than ones made more recently, in terms of design, durability, and quality control, and that their Customer Support has latterly been trending towards the dismal. I should note that I've been a long-term customer for some of their products, though with not much by way of recent examples.
Other than a bug in the C922 (EDIT: not C922 but C920S) that someone else mentioned in a recent thread here, which is not exhibited in its older cousins the c920, and c930e, I have not witnessed ANY drop in quality control with Logi items. And in fact have been very pleased by their corporate performance, even during our recent pandemic trials.
I have to grade quality for AV tech for my University, and I would still now give them an overall A (maybe B+). No complaints here.
Btw, I bought my spouse a k780 for her work about 18 months ago, and I liked it so much (and kept borrowing it) that she got me one for my birthday, just so I'd leave hers alone.
ScottLast edited by Cornucopia; 18th Aug 2020 at 19:40.
Seeking Broad Downsampling Advice
By enter8 in forum Newbie / General discussionsReplies: 3Last Post: 18th Sep 2019, 12:04 -
New TV problem. Seeking advice.
By Aldbaran in forum Off topicReplies: 2Last Post: 14th May 2018, 00:38 -
Video newb requesting advice for hardware/software - for pc/ipad screen vid
By Xophe in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jan 2018, 18:36 -
Seeking advice on purchasing camera stabilizer
By satimis in forum Off topicReplies: 0Last Post: 18th Jan 2018, 02:52 -
Seeking advice on capture card for PC
By three_jeeps in forum Capturing and VCRReplies: 2Last Post: 11th Feb 2016, 00:55
![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
though not yet assigned to that task]
Shuttle SH67H3 (i7)
w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
services for an office, with other computers
there . . . ]
Various older model Lenovo laptops, like T-40
series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
& various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
