First of all thanks for any reply great site!
I use easydivx0.81
very easy to use I have to say and it creates very good AVI format from my DVD
I set it to 2 cd's (635Mb)and let it run (divx5.01codec constant bitrate)
I use nero and try to make an SVCD
and here it is where I go wrong (less quality)shunky parts
I try to make from cd 1 after easydivx081 sized (666Mb)
a SVCD fit on 79min and let it encode.
The quality is not what I expected which setting do I have to use to gain the same quality as the superb made AVI thru easydivx081
the output easydivx avi is
audio
audio format= Mpeg layer3
average data rate= 16.00Kb/second
sample rate= 44.100 Khz
channels= 2 stereo
video
streamname= mpeg2avi{IDCT32MMX}'-q0'
framewidth= 720pixels
frameheight= 576pixels
playlenght= 2724.720seconds
framecount= 68118
framerate= 25frames/second
datarate= 233.110 Kb/sec
videosample size= 24bits
videocompression= divx codec
If more info needed please let me know?
Thanks for all replies!
well might want to use a different codec as divx is a VERY lossy codec and often loses sync when converted to mpeg
Which codec and program would you suggest to use?
And can It be coded straight from the dvd to Mpeg2 which Nero can burn as SVCD is suchs a program available and what setting would I have to use -
i'd use either sefy's guide or doom9's, you can find both in the dvdrip section. and maybe not use nero 5.5.8.0 seems to be less compatible than previous versions...
paulhoopen, why are you encoding to DivX and then to SVCD ??? that is a complete waste of time and quality! encoder straight to SVCD or VCD, i'd recommand you follow the guides and see how it goes for you.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
How many things can you find wrong with this CL post ???
By Noahtuck in forum Off topicReplies: 1Last Post: 18th Mar 2012, 13:27 -
DVD+R won't play, have I bought the wrong format? - New post/problem 15/12
By yultie in forum MediaReplies: 20Last Post: 17th Dec 2010, 14:59 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 10:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 19:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 05:11
