Results 1 to 1 of 1
  1. Just started using this. Pretty good but struggling a little. I am trying to create simple transitions between image clips - fade in and fade out. This is proving difficult, sometimes they sort of work others, not at all. Fade in = 00.00.5 Fade out = 00.00.5. The clips are overlapping. So the first should fade out as the other fades in - simple. No, the fade out is not too bad - the fade in just doesn't seem to work.
    Any suggestions, please?
    Cheers,
    Mike
