I have a video file from a ProRes recorder (Odyssey 7Q+) and when I copy an audio stream to a new file, ffmpeg seems to be changing the audio properties, including the codec. MediaInfo also says the original audio is signed, and the new audio is unsigned.
ffmpeg i Video1.mov -map 0:6 -c copy New video.mov
Original Audio (stream 0:6): pcm_s32be (lpcm / 0x6D63706C), 48000 Hz, 2 channels, s32, 3072 kb/s (default)
New Audio (stream 0:0): pcm_s32be (in32 / 0x32336E69), 48000 Hz, stereo, s32, 3072 kb/s (default)
Any help is appreciated!
Results 1 to 11 of 11
You can try submitting a ffmpeg bug report ticket to have a developer look at it
https://trac.ffmpeg.org/wiki
or try asking CD, they have good support -
Thanks jagabo. In the hex editor I changed in32 entries to lpcm. After this ffmpeg displayed:
Audio: pcm_s16be (lpcm / 0x6D63706C), 48000 Hz, stereo, s16, 1536 kb/s (default)
Which is the correct codec label, but it is now listed as 16bit and 1536 kb/s (instead of 32bit, 3072 kb/s). Media Info also reported 16bit, but now the audio was signed (as it was supposed to be originally)
I figure these results are a mistake (due to me messing around with the hex editor), as the file size didn't change. The Convergent Design CDProRes Transfer Tool now muxes the files, but the audio for the newly replaced section is just bursts of static. Image is fine, and audio for the rest is fine. So I am making progress. Thanks for the help.
Still not sure how to make end up with lpcm and 32bit though... -
I ended up messing around more with the hex editor and finally got the desired results. Thanks again for your suggestions, jagabo.
FFMpeg merging audio files truncates output to shortest audio file
By Wayneos in forum Video ConversionReplies: 0Last Post: 3rd Jul 2019, 07:07 -
MKVtoolnix : adding an audio track results in warnings and corrupted audio
By Jose Hidalgo in forum EditingReplies: 10Last Post: 9th Mar 2018, 11:48 -
FFMPEG or FFMBC on xdcamhd422 files: how to copy audio track4 into track2?
By marcorocchini in forum Newbie / General discussionsReplies: 11Last Post: 11th Aug 2017, 15:25 -
Please help: This ffmpeg command won't convert AND copy/passthru audio
By mp4_guy in forum AudioReplies: 2Last Post: 24th Jun 2016, 08:15 -
FFMPEG: can "select" audio channels using -acodec copy?
By marcorocchini in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2015, 19:04
