Hi have just purchased Toast 18
having terrible trouble with their so called tech support so am coming on here for hopefully some proper advice.
I have finished QT MP4s on my desktop that I want to burn to blue ray BDXL discs. They are 70 and 90 gbs in size.
When I drag and drop them into the TOAST template they are just showing up as 904kb in size in the information bar at the bottom.
I am wondering if it is a codec issue, the original IMOVIE projects have been saved as Apple Pro Res files 422, do I need to convert them
to H264 Codecs for TOAST to see the correct size ?. I am writing to a Pioneer ext BD Player that is 100 GB compliant, so that's not the issue.
Any help anyone could give me on here would be so grateful.
Thank You.
Results 1 to 1 of 1
Chapters for multiple videos in Toast 11
By erbaggio in forum Authoring (Blu-ray)Replies: 1Last Post: 24th Mar 2019, 10:55 -
Toast video tab for PC
By danielmak in forum MacReplies: 0Last Post: 4th Sep 2018, 10:02 -
Toast: Not enough space on DVD-R
By kaspar in forum MacReplies: 3Last Post: 27th Aug 2018, 04:49 -
Toast 14 can only fit 3 files on dvd
By sweetcorn in forum MacReplies: 22Last Post: 23rd Feb 2016, 00:06 -
Optimal Toast DVD settings
By MikeBintouch in forum MacReplies: 21Last Post: 6th Apr 2015, 11:33
