Results 1 to 19 of 19
  1. is there a way to remove the first and last lines of all subtitles by bulk/batch automatically? its just author's name and website info.
    Windows 10, MPC-BE
  2. bulk search and replace with a text editor
  3. Can you explain how? I do have notepad++ but the problem would be it would still leave behind the timecodes. I assume some syntax or expression?
    Windows 10, MPC-BE
  4. enter the srt code for example
    so i can tell you how and what to replace
    Jul 2007
    What type of subtitles, .srt, .ass, .sub, etc? Some media players may not display a blank subtitle line correctly and you'll have to run them through a subtitle editor to properly renumber the remaining lines.
    For .srt, I've been using InfoRapid Search and Replace for https://www.snapfiles.com/get/irapid.html, then running them through SubMagic to renumber the lines.
  6. Ok it's an ASS file, but I could get the original SRT file either way.
    [Script Info]
    ; This is an Advanced Sub Station Alpha v4+ script.
    Title: Breaking Bad S02E01 Seven Thirty-Seven
    ScriptType: v4.00+
    Collisions: Normal
    PlayDepth: 0
    [V4+ Styles]
    Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding
    Style: Default,Arial,16,&H00FFFFFF,&H000000FF,&H00000000,&H00000000,1,0,0,0,100,100,0,0,3,2,0,2,10,10,10,1
    [Events]
    Format: Layer, Start, End, Style, Actor, MarginL, MarginR, MarginV, Effect, Text
    Dialogue: 0,0:00:01.00,0:00:06.24,Default,,0000,0000,0010,,{\fs20\a2}Subs collected, corrected and if necessary re-synced by Tronar for\N"Breaking Bad Season 1, 2, 3, 4 & 5 + Extras BDRip DVDRip HDTV TSV"
    Windows 10, MPC-BE
  7. Notepad++ menu
    SEARCH FIND IN FILES
    ^.*Subs collected.*
    Replace with Nothing
    Click on Regular Expression
    From Director select directory of files to replace
    Filters *.ass
  8. ^Style\: Default.*Subs collected.*$ this did not work, "0 files replaced". Also tried just *Subs collected.*$
    Windows 10, MPC-BE
  9. ^.*Subs collected.*
    Sorry My Mistake
  10. still not working. 0 occurrences replaced
    Windows 10, MPC-BE
  11. Did you select regular expression from the options?
  12. yes. but i didnt check ". matches newline" should i try that?
    Windows 10, MPC-BE
    Jul 2011
    Denmark
    You could try Subtitle Edit, Tools -> Batch convert. Enable "Multiple replace" and use "Example 3" regex from here: https://nikse.dk/SubtitleEdit/Help#multiple_replace
  14. Hmm It removed all the dialogue, not just the first and last. I had given the short version of the code. Here is the full code (some lines removed for 50k limit)
    [Script Info]
    Title: Breaking Bad S04E07 Problem Dog
    ScriptType: v4.00+
    Collisions: Normal
    PlayDepth: 0
    [V4+ Styles]
    [Events]
    Dialogue: 0,0:00:02.00,0:00:07.24,Default,,0000,0000,0010,,{s202}Subs collected, corrected and if necessary re-synced by Tronar for\N"Breaking Bad Season 1, 2, 3, 4 & 5 + Extras BDRip DVDRip HDTV TSV"
    Dialogue: 0,0:00:24.27,0:00:25.69,Default,,0000,0000,0010,,{s202}It came out of nowhere.
    Dialogue: 0,0:00:25.85,0:00:28.36,Default,,0000,0000,0010,,{s202}You gotta help us.
    Dialogue: 0,0:00:30.69,0:00:33.53,Default,,0000,0000,0010,,{s202}- Look at all this damn water.\N- Don't drink that.
    Dialogue: 0,0:26:48.73,0:26:53.27,Default,,0000,0000,0010,,{s202}I don't wanna see that in your hand\Nunless you see me with mine.
    Dialogue: 0,0:26:53.44,0:26:55.82,Default,,0000,0000,0010,,{s202}Emergency only.
    Dialogue: 0,0:26:56.65,0:26:58.90,Default,,0000,0000,0010,,{s202}First car is coming.
    Dialogue: 0,0:27:02.49,0:27:05.29,Default,,0000,0000,0010,,{s202}All right,\Nwhat's the order of the day?
    Dialogue: 0,0:27:05.58,0:27:07.83,Default,,0000,0000,0010,,{s202}Eyes open, mouth shut.
    Dialogue: 0,0:28:12.14,0:28:14.10,Default,,0000,0000,0010,,{s202}A lot of guns.
    Dialogue: 0,0:28:14.27,0:28:17.23,Default,,0000,0000,0010,,{s202}Nobody's asking you\Nto give up yours.
    Dialogue: 0,0:28:20.40,0:28:23.57,Default,,0000,0000,0010,,{s202}You wanna sweep the place\Nbefore you bring in your guys?
    Dialogue: 0,0:28:24.07,0:28:26.20,Default,,0000,0000,0010,,{s202}I am the guy.
    Dialogue: 0,0:28:29.50,0:28:31.58,Default,,0000,0000,0010,,{s202}All right, then.
    Dialogue: 0,0:28:35.38,0:28:37.21,Default,,0000,0000,0010,,{s202}Welcome.
    Dialogue: 0,0:28:38.59,0:28:40.51,Default,,0000,0000,0010,,{s202}Where is the rest of your party?
    Dialogue: 0,0:28:42.22,0:28:43.80,Default,,0000,0000,0010,,{s202}I am the only one coming.
    Dialogue: 0,0:28:44.39,0:28:45.84,Default,,0000,0000,0010,,{s202}And why is that?
    Dialogue: 0,0:28:46.47,0:28:50.93,Default,,0000,0000,0010,,{s202}My employers feel I can adequately\Nrepresent their interests.
    Dialogue: 0,0:28:55.06,0:28:56.48,Default,,0000,0000,0010,,{s202}Please, sit.
    Dialogue: 0,0:29:11.66,0:29:13.12,Default,,0000,0000,0010,,{s202}This is my offer.
    Dialogue: 0,0:29:13.50,0:29:18.21,Default,,0000,0000,0010,,{s202}In consideration\Nof our previous relationship...
    Dialogue: 0,0:29:20.30,0:29:24.67,Default,,0000,0000,0010,,{s202}...I will make a one-time payment...
    Dialogue: 0,0:29:24.84,0:29:29.22,Default,,0000,0000,0010,,{s202}...of 50 million U.S. dollars.
    Dialogue: 0,0:29:32.89,0:29:36.77,Default,,0000,0000,0010,,{s202}In return our business is concluded.
    Dialogue: 0,0:29:37.90,0:29:41.36,Default,,0000,0000,0010,,{s202}No further payments.\NNo further contact.
    Dialogue: 0,0:29:41.57,0:29:44.40,Default,,0000,0000,0010,,{s202}An absolute severance.
    Dialogue: 0,0:29:54.37,0:29:56.58,Default,,0000,0000,0010,,{s202}You have no response?
    Dialogue: 0,0:30:23.98,0:30:26.40,Default,,0000,0000,0010,,{s202}This is not a negotiation.
    Dialogue: 0,0:31:25.63,0:31:27.17,Default,,0000,0000,0010,,{s202}You got something of mine?
    Dialogue: 0,0:31:34.72,0:31:36.81,Default,,0000,0000,0010,,{s202}Glove box.
    Dialogue: 0,0:31:40.64,0:31:43.23,Default,,0000,0000,0010,,{s202}Figure I better teach you\Nhow to shoot.
    Dialogue: 0,0:31:43.40,0:31:45.44,Default,,0000,0000,0010,,{s202}Could be things are gonna get hairy.
    Dialogue: 0,0:31:48.32,0:31:50.32,Default,,0000,0000,0010,,{s202}What is this?
    Dialogue: 0,0:31:50.82,0:31:54.03,Default,,0000,0000,0010,,{s202}I mean, you're giving me a gun...
    Dialogue: 0,0:31:54.20,0:31:57.99,Default,,0000,0000,0010,,{s202}...and now I'm, like, part of the team\Nor whatever?
    Dialogue: 0,0:32:00.46,0:32:03.29,Default,,0000,0000,0010,,{s202}He said he sees something in me.
    Dialogue: 0,0:32:04.46,0:32:05.67,Default,,0000,0000,0010,,{s202}Like what?
    Dialogue: 0,0:32:09.76,0:32:12.47,Default,,0000,0000,0010,,{s202}If I had to put it in a word...
    Dialogue: 0,0:32:13.30,0:32:17.10,Default,,0000,0000,0010,,{s202}...I'd guess loyalty.
    Dialogue: 0,0:32:17.26,0:32:19.14,Default,,0000,0000,0010,,{s202}Loyalty.
    Dialogue: 0,0:32:23.19,0:32:26.48,Default,,0000,0000,0010,,{s202}Only maybe you got it\Nfor the wrong guy.
    Dialogue: 0,0:32:44.50,0:32:46.17,Default,,0000,0000,0010,,{s202}Jesse?
    Dialogue: 0,0:32:47.21,0:32:48.88,Default,,0000,0000,0010,,{s202}- Hey.\N- Hey.
    Dialogue: 0,0:32:49.05,0:32:51.01,Default,,0000,0000,0010,,{s202}Long time, no see.
    Dialogue: 0,0:32:53.55,0:32:55.34,Default,,0000,0000,0010,,{s202}How you doing?
    Dialogue: 0,0:32:55.51,0:32:57.30,Default,,0000,0000,0010,,{s202}Yeah, you know...
    Dialogue: 0,0:32:57.85,0:33:00.60,Default,,0000,0000,0010,,{s202}- ...good.\N- Good.
    Dialogue: 0,0:33:00.93,0:33:02.60,Default,,0000,0000,0010,,{s202}Good.
    Dialogue: 0,0:33:04.23,0:33:07.69,Default,,0000,0000,0010,,{s202}Okay, we're gonna get started.\NYou coming in?
    Dialogue: 0,0:33:11.40,0:33:14.90,Default,,0000,0000,0010,,{s202}So the truth is, we can't change\Nthe past, what's done is done.
    Dialogue: 0,0:33:15.07,0:33:18.53,Default,,0000,0000,0010,,{s202}We've gotta own our actions,\Nbut putting ourselves on trial...
    Dialogue: 0,0:33:18.70,0:33:22.66,Default,,0000,0000,0010,,{s202}...acting as our own judge, jury\Nand executioner, it's not the answer.
    Dialogue: 0,0:33:22.83,0:33:25.16,Default,,0000,0000,0010,,{s202}A lot of the time,\Nall that judging does...
    Dialogue: 0,0:33:25.33,0:33:29.75,Default,,0000,0000,0010,,{s202}...is just ensure\Nthat we're gonna repeat the cycle.
    Dialogue: 0,0:33:29.92,0:33:31.71,Default,,0000,0000,0010,,{s202}Right?
    Dialogue: 0,0:33:32.34,0:33:34.09,Default,,0000,0000,0010,,{s202}"I'm such an *******.
    Dialogue: 0,0:33:34.26,0:33:38.09,Default,,0000,0000,0010,,{s202}It's totally hopeless,\Nwhat's the point?
    Dialogue: 0,0:33:38.26,0:33:40.14,Default,,0000,0000,0010,,{s202}I think I'll have a hit."
    Dialogue: 0,0:33:41.56,0:33:42.60,Default,,0000,0000,0010,,{s202}Jesse...
    Dialogue: 0,0:33:43.43,0:33:46.06,Default,,0000,0000,0010,,{s202}...what's going on with you\Nthese days?
    Dialogue: 0,0:33:49.48,0:33:52.40,Default,,0000,0000,0010,,{s202}I went back to the crystal.
    Dialogue: 0,0:33:52.57,0:33:54.69,Default,,0000,0000,0010,,{s202}You sober now?
    Dialogue: 0,0:33:55.28,0:33:56.36,Default,,0000,0000,0010,,{s202}Yeah.
    Dialogue: 0,0:33:56.53,0:33:58.20,Default,,0000,0000,0010,,{s202}Four days.
    Dialogue: 0,0:33:58.37,0:33:59.45,Default,,0000,0000,0010,,{s202}Big whoop, right?
    Dialogue: 0,0:33:59.62,0:34:01.41,Default,,0000,0000,0010,,{s202}Hey, four days is four days.
    Dialogue: 0,0:34:01.58,0:34:02.99,Default,,0000,0000,0010,,{s202}You're here.
    Dialogue: 0,0:34:03.75,0:34:05.58,Default,,0000,0000,0010,,{s202}You still...
    Dialogue: 0,0:34:05.87,0:34:08.62,Default,,0000,0000,0010,,{s202}...working at the laundry?
    Dialogue: 0,0:34:08.79,0:34:09.96,Default,,0000,0000,0010,,{s202}How are things there?
    Dialogue: 0,0:34:11.21,0:34:13.55,Default,,0000,0000,0010,,{s202}Sucks ass.
    Dialogue: 0,0:34:15.51,0:34:17.26,Default,,0000,0000,0010,,{s202}Anything you wanna talk about?
    Dialogue: 0,0:34:27.44,0:34:29.73,Default,,0000,0000,0010,,{s202}A couple of weeks back...
    Dialogue: 0,0:34:32.61,0:34:34.53,Default,,0000,0000,0010,,{s202}...I killed a dog.
    Dialogue: 0,0:34:37.90,0:34:39.78,Default,,0000,0000,0010,,{s202}You hit it with your car?
    Dialogue: 0,0:34:42.62,0:34:44.33,Default,,0000,0000,0010,,{s202}No.
    Dialogue: 0,0:34:45.41,0:34:47.58,Default,,0000,0000,0010,,{s202}I put him down.
    Dialogue: 0,0:34:48.46,0:34:50.50,Default,,0000,0000,0010,,{s202}I watched him go.
    Dialogue: 0,0:34:50.88,0:34:53.88,Default,,0000,0000,0010,,{s202}I was looking him straight in the eye.
    Dialogue: 0,0:34:56.30,0:34:59.76,Default,,0000,0000,0010,,{s202}He didn't know what was happening.\NHe didn't know why. He...
    Dialogue: 0,0:35:01.05,0:35:04.14,Default,,0000,0000,0010,,{s202}He was just scared.
    Dialogue: 0,0:35:06.39,0:35:08.18,Default,,0000,0000,0010,,{s202}And then he was gone.
    Dialogue: 0,0:35:08.94,0:35:10.90,Default,,0000,0000,0010,,{s202}He was suffering.
    Dialogue: 0,0:35:11.06,0:35:12.81,Default,,0000,0000,0010,,{s202}It was a kindness.
    Dialogue: 0,0:35:14.07,0:35:16.69,Default,,0000,0000,0010,,{s202}No, he wasn't sick.
    Dialogue: 0,0:35:19.07,0:35:21.45,Default,,0000,0000,0010,,{s202}No. He was just, like...
    Dialogue: 0,0:35:22.82,0:35:24.83,Default,,0000,0000,0010,,{s202}I don't know, like, a...
    Dialogue: 0,0:35:25.79,0:35:27.87,Default,,0000,0000,0010,,{s202}...problem dog.
    Dialogue: 0,0:35:28.04,0:35:29.87,Default,,0000,0000,0010,,{s202}What did he do?
    Dialogue: 0,0:35:30.04,0:35:31.08,Default,,0000,0000,0010,,{s202}Bite someone?
    Dialogue: 0,0:35:34.25,0:35:36.30,Default,,0000,0000,0010,,{s202}No, this dog never...
    Dialogue: 0,0:35:36.46,0:35:39.01,Default,,0000,0000,0010,,{s202}Never bit anybody.
    Dialogue: 0,0:35:40.01,0:35:43.89,Default,,0000,0000,0010,,{s202}You pick up the rock,\Nyou go right to the dark side.
    Dialogue: 0,0:35:44.10,0:35:45.18,Default,,0000,0000,0010,,{s202}Anything can happen.
    Dialogue: 0,0:35:45.35,0:35:47.68,Default,,0000,0000,0010,,{s202}It ain't no rock that made me do it.
    Dialogue: 0,0:35:47.85,0:35:50.31,Default,,0000,0000,0010,,{s202}What was the problem?\NWhy did you kill him?
    Dialogue: 0,0:35:50.48,0:35:52.73,Default,,0000,0000,0010,,{s202}Watch the crosstalk, please.
    Dialogue: 0,0:35:54.36,0:35:57.94,Default,,0000,0000,0010,,{s202}Maybe it's not the details that matter,\Nright?
    Dialogue: 0,0:35:58.44,0:36:00.86,Default,,0000,0000,0010,,{s202}How do you feel about what you did,\NJesse?
    Dialogue: 0,0:36:03.82,0:36:05.91,Default,,0000,0000,0010,,{s202}I don't know.
    Dialogue: 0,0:36:07.29,0:36:10.25,Default,,0000,0000,0010,,{s202}Who cares how you feel?
    Dialogue: 0,0:36:10.91,0:36:13.21,Default,,0000,0000,0010,,{s202}What kind of person kills a dog\Nfor no reason?
    Dialogue: 0,0:36:13.38,0:36:14.46,Default,,0000,0000,0010,,{s202}Colleen.
    Dialogue: 0,0:36:14.63,0:36:17.34,Default,,0000,0000,0010,,{s202}Put an ad in the paper,\Ndrop him off at a shelter.
    Dialogue: 0,0:36:17.50,0:36:21.67,Default,,0000,0000,0010,,{s202}You don't just sit there and talk about\Nkilling a helpless, innocent animal.
    Dialogue: 0,0:36:22.84,0:36:24.76,Default,,0000,0000,0010,,{s202}We're not here to sit in judgment.
    Dialogue: 0,0:36:25.64,0:36:27.43,Default,,0000,0000,0010,,{s202}Why not?
    Dialogue: 0,0:36:28.64,0:36:31.35,Default,,0000,0000,0010,,{s202}Why not? Maybe she's right.
    Dialogue: 0,0:36:31.52,0:36:36.06,Default,,0000,0000,0010,,{s202}Maybe I should have put it in the paper.\NI should've done something different.
    Dialogue: 0,0:36:37.77,0:36:43.53,Default,,0000,0000,0010,,{s202}The thing is, if you just do stuff\Nand nothing happens...
    Dialogue: 0,0:36:44.91,0:36:47.28,Default,,0000,0000,0010,,{s202}...what's it all mean?
    Dialogue: 0,0:36:47.83,0:36:49.16,Default,,0000,0000,0010,,{s202}What's the point?
    Dialogue: 0,0:36:51.16,0:36:55.50,Default,,0000,0000,0010,,{s202}Oh, right, this whole thing\Nis about self-acceptance.
    Dialogue: 0,0:36:55.67,0:36:58.96,Default,,0000,0000,0010,,{s202}Kicking yourself\Ndoesn't give meaning to anything.
    Dialogue: 0,0:36:59.13,0:37:03.30,Default,,0000,0000,0010,,{s202}So I should stop judging...
    Dialogue: 0,0:37:04.05,0:37:06.39,Default,,0000,0000,0010,,{s202}- ...and accept?\N- It's a start.
    Dialogue: 0,0:37:06.55,0:37:09.22,Default,,0000,0000,0010,,{s202}So no matter what I do...
    Dialogue: 0,0:37:09.39,0:37:11.77,Default,,0000,0000,0010,,{s202}...hooray for me\Nbecause I'm a great guy?
    Dialogue: 0,0:37:11.93,0:37:14.02,Default,,0000,0000,0010,,{s202}It's all good?
    Dialogue: 0,0:37:14.35,0:37:20.77,Default,,0000,0000,0010,,{s202}No matter how many dogs I kill, I just,\Nwhat, do an inventory and accept?
    Dialogue: 0,0:37:23.40,0:37:28.62,Default,,0000,0000,0010,,{s202}I mean, you back your truck over\Nyour own kid and you, like, accept?
    Dialogue: 0,0:37:29.58,0:37:31.95,Default,,0000,0000,0010,,{s202}- What a load of crap?\N- Hey, Jesse.
    Dialogue: 0,0:37:32.12,0:37:33.33,Default,,0000,0000,0010,,{s202}I know you're in pain.
    Dialogue: 0,0:37:33.50,0:37:35.58,Default,,0000,0000,0010,,{s202}No, you know what?
    Dialogue: 0,0:37:36.79,0:37:40.04,Default,,0000,0000,0010,,{s202}Why I'm here in the first place?
    Dialogue: 0,0:37:41.80,0:37:44.59,Default,,0000,0000,0010,,{s202}Is to sell you meth.
    Dialogue: 0,0:37:46.97,0:37:50.30,Default,,0000,0000,0010,,{s202}You're nothing to me but customers!
    Dialogue: 0,0:37:54.43,0:37:56.27,Default,,0000,0000,0010,,{s202}I made you my bitch.
    Dialogue: 0,0:37:56.44,0:37:58.85,Default,,0000,0000,0010,,{s202}You okay with that?
    Dialogue: 0,0:38:00.32,0:38:02.52,Default,,0000,0000,0010,,{s202}You accept?
    Dialogue: 0,0:38:04.32,0:38:05.65,Default,,0000,0000,0010,,{s202}No.
    Dialogue: 0,0:38:15.50,0:38:17.62,Default,,0000,0000,0010,,{s202}About time.
    Dialogue: 0,0:38:47.61,0:38:50.20,Default,,0000,0000,0010,,{s202}Jesse.
    Dialogue: 0,0:38:50.37,0:38:52.91,Default,,0000,0000,0010,,{s202}Bring a light over here, will you?
    Dialogue: 0,0:39:05.13,0:39:07.59,Default,,0000,0000,0010,,{s202}Do you see any residue there?
    Dialogue: 0,0:39:08.55,0:39:13.60,Default,,0000,0000,0010,,{s202}- Where?\N- Here. On the bottom, right there.
    Dialogue: 0,0:39:15.97,0:39:18.93,Default,,0000,0000,0010,,{s202}It's been a week. What's going on?
    Dialogue: 0,0:39:19.64,0:39:21.85,Default,,0000,0000,0010,,{s202}I haven't seen him.
    Dialogue: 0,0:39:23.48,0:39:27.48,Default,,0000,0000,0010,,{s202}I didn't think so. But I'll just give it\Nanother shot anyway.
    Dialogue: 0,0:39:50.84,0:39:53.59,Default,,0000,0000,0010,,{s202}- Hey.\N- Hey, buddy. Look at that.
    Dialogue: 0,0:39:53.76,0:39:57.39,Default,,0000,0000,0010,,{s202}Graduated to doorman.\NFinally found your calling.
    Dialogue: 0,0:39:57.56,0:39:59.48,Default,,0000,0000,0010,,{s202}Oh, little whiskers, Marie.
    Dialogue: 0,0:39:59.64,0:40:00.68,Default,,0000,0000,0010,,{s202}What did you do?
    Dialogue: 0,0:40:00.85,0:40:05.11,Default,,0000,0000,0010,,{s202}Show your barber a picture\Nof a dog's ass and said, "I'll take that"?
    Dialogue: 0,0:40:05.27,0:40:06.52,Default,,0000,0000,0010,,{s202}Charming as usual.
    Dialogue: 0,0:40:06.69,0:40:07.90,Default,,0000,0000,0010,,{s202}Welcome back.
    Dialogue: 0,0:40:08.07,0:40:10.32,Default,,0000,0000,0010,,{s202}- Looking good, Marie.\N- Thanks, Steve.
    Dialogue: 0,0:40:10.49,0:40:14.66,Default,,0000,0000,0010,,{s202}- Good to see you. How you doing?\N- He's fine. We can take it from here.
    Dialogue: 0,0:40:14.82,0:40:16.83,Default,,0000,0000,0010,,{s202}- Yeah.\N- If you wanna hold his elbow.
    Dialogue: 0,0:40:16.99,0:40:21.08,Default,,0000,0000,0010,,{s202}No, no, no. You keep your mitts off me.\NI'm good. I'm good.
    Dialogue: 0,0:40:24.33,0:40:25.38,Default,,0000,0000,0010,,{s202}Hey.
    Dialogue: 0,0:40:26.92,0:40:28.38,Default,,0000,0000,0010,,{s202}Good luck.
    Dialogue: 0,0:40:33.43,0:40:35.80,Default,,0000,0000,0010,,{s202}Let's go, we're running late.\NCome on.
    Dialogue: 0,0:40:40.52,0:40:45.27,Default,,0000,0000,0010,,{s202}Hank, seeing you walk in here, I can't\Ntell you what that means to all of us.
    Dialogue: 0,0:40:45.44,0:40:48.61,Default,,0000,0000,0010,,{s202}Your progress, it's incredible.
    Dialogue: 0,0:40:48.78,0:40:52.11,Default,,0000,0000,0010,,{s202}Yeah, well, chalk it up to clean living\Nand vitamin pills.
    Dialogue: 0,0:40:53.24,0:40:55.91,Default,,0000,0000,0010,,{s202}- Steve tell you his news?\N- What?
    Dialogue: 0,0:40:56.07,0:40:58.16,Default,,0000,0000,0010,,{s202}Finally got your period?
    Dialogue: 0,0:40:58.37,0:41:00.20,Default,,0000,0000,0010,,{s202}I made GS-14.
    Dialogue: 0,0:41:00.37,0:41:02.08,Default,,0000,0000,0010,,{s202}Wow, that's all right, man.
    Dialogue: 0,0:41:02.25,0:41:05.12,Default,,0000,0000,0010,,{s202}Next stop: Washington, D.C.\NSitting behind a desk...
    Dialogue: 0,0:41:05.29,0:41:07.75,Default,,0000,0000,0010,,{s202}...papers piled so high,\Nyou can't see over them.
    Dialogue: 0,0:41:07.92,0:41:09.75,Default,,0000,0000,0010,,{s202}Hey, better you than me, buddy.
    Dialogue: 0,0:41:09.92,0:41:11.96,Default,,0000,0000,0010,,{s202}Seriously, congratulations, buddy.
    Dialogue: 0,0:41:12.13,0:41:13.55,Default,,0000,0000,0010,,{s202}Thanks.
    Dialogue: 0,0:41:13.72,0:41:16.05,Default,,0000,0000,0010,,{s202}Steve said you might have something\Nfor us.
    Dialogue: 0,0:41:16.22,0:41:19.22,Default,,0000,0000,0010,,{s202}Yeah, maybe.\NYou guys are gonna have to tell me.
    Dialogue: 0,0:41:20.14,0:41:22.43,Default,,0000,0000,0010,,{s202}Remember my pal Tim Roberts?
    Dialogue: 0,0:41:22.60,0:41:23.89,Default,,0000,0000,0010,,{s202}APD detective?
    Dialogue: 0,0:41:24.06,0:41:26.31,Default,,0000,0000,0010,,{s202}Yeah, well, he's working\Non a murder case.
    Dialogue: 0,0:41:26.48,0:41:28.94,Default,,0000,0000,0010,,{s202}The victim's a 34-year-old\Nmale Caucasian...
    Dialogue: 0,0:41:29.11,0:41:31.23,Default,,0000,0000,0010,,{s202}...by the name of Gale Boetticher.
    Dialogue: 0,0:41:31.40,0:41:34.70,Default,,0000,0000,0010,,{s202}One night last month,\NBoetticher opens the door...
    Dialogue: 0,0:41:35.07,0:41:39.32,Default,,0000,0000,0010,,{s202}...takes a bullet to the face\Nfrom a person or persons unknown.
    Dialogue: 0,0:41:39.49,0:41:43.41,Default,,0000,0000,0010,,{s202}Now, this Gale Boetticher\Nis a bona fide chemistry genius.
    Dialogue: 0,0:41:43.58,0:41:46.62,Default,,0000,0000,0010,,{s202}I mean, he's got degrees\Nup the wazoo, right?
    Dialogue: 0,0:41:46.79,0:41:51.09,Default,,0000,0000,0010,,{s202}And, well, as you might expect,\Nhe's a nerd's nerd.
    Dialogue: 0,0:41:51.25,0:41:54.13,Default,,0000,0000,0010,,{s202}Vegan, sandals and socks\Nkind of guy.
    Dialogue: 0,0:41:54.30,0:41:59.55,Default,,0000,0000,0010,,{s202}As it turns out, he's also\Nan A-number-one meth cook.
    Dialogue: 0,0:41:59.72,0:42:04.85,Default,,0000,0000,0010,,{s202}And what caught my eye\Nis his specialty product is blue.
    Dialogue: 0,0:42:05.44,0:42:07.10,Default,,0000,0000,0010,,{s202}So, what are you thinking?
    Dialogue: 0,0:42:07.27,0:42:08.65,Default,,0000,0000,0010,,{s202}This is your Heisenberg?
    Dialogue: 0,0:42:09.73,0:42:14.57,Default,,0000,0000,0010,,{s202}No. What I think we got here\Nis Heisenberg's former cook...
    Dialogue: 0,0:42:14.74,0:42:18.32,Default,,0000,0000,0010,,{s202}...and maybe a line\Non Heisenberg himself.
    Dialogue: 0,0:42:20.07,0:42:25.04,Default,,0000,0000,0010,,{s202}Anyway, lo and behold,\Namidst all the hippie-dippy nonsense...
    Dialogue: 0,0:42:25.66,0:42:27.08,Default,,0000,0000,0010,,{s202}...I find this.
    Dialogue: 0,0:42:27.79,0:42:31.29,Default,,0000,0000,0010,,{s202}Now, this here,\NI do a little Google-fu...
    Dialogue: 0,0:42:31.46,0:42:36.09,Default,,0000,0000,0010,,{s202}...and I realize it's a parts number\Nspecifically for this baby.
    Dialogue: 0,0:42:37.84,0:42:43.64,Default,,0000,0000,0010,,{s202}That there is a high-volume\NHEPA industrial air filtration system.
    Dialogue: 0,0:42:43.93,0:42:45.68,Default,,0000,0000,0010,,{s202}That's a 300,000-dollar gadget.
    Dialogue: 0,0:42:45.85,0:42:50.15,Default,,0000,0000,0010,,{s202}Perfect for a pharmaceutical plant\Nor microchip factory...
    Dialogue: 0,0:42:50.31,0:42:55.40,Default,,0000,0000,0010,,{s202}...or maybe the biggest meth lab\Nnorth of the border.
    Dialogue: 0,0:42:57.20,0:42:58.99,Default,,0000,0000,0010,,{s202}Okay.
    Dialogue: 0,0:42:59.16,0:43:01.66,Default,,0000,0000,0010,,{s202}So this little dingus here\Nis manufactured...
    Dialogue: 0,0:43:01.82,0:43:06.95,Default,,0000,0000,0010,,{s202}...by a big international concern:\NMadrigal Electromotive.
    Dialogue: 0,0:43:07.12,0:43:11.75,Default,,0000,0000,0010,,{s202}I call their Houston office, I get through\Nto the nicest little 20-year-old temp.
    Dialogue: 0,0:43:11.92,0:43:16.00,Default,,0000,0000,0010,,{s202}I use the Schrader sweet-talk.\NBefore you know it, she's pulling files.
    Dialogue: 0,0:43:16.17,0:43:21.59,Default,,0000,0000,0010,,{s202}Six months ago, one of these systems\Nwas shipped to a depot here in ABQ.
    Dialogue: 0,0:43:21.76,0:43:23.80,Default,,0000,0000,0010,,{s202}Who signed for it?
    Dialogue: 0,0:43:24.22,0:43:25.35,Default,,0000,0000,0010,,{s202}Gale Boetticher.
    Dialogue: 0,0:43:26.02,0:43:31.44,Default,,0000,0000,0010,,{s202}So I asked my new girlfriend, "Who\Npaid for it?" And she says, "Nobody."
    Dialogue: 0,0:43:32.56,0:43:36.57,Default,,0000,0000,0010,,{s202}They have no record that anybody\Nactually paid for this thing.
    Dialogue: 0,0:43:36.73,0:43:40.20,Default,,0000,0000,0010,,{s202}So I go back and push more\Nand before you know it...
    Dialogue: 0,0:43:40.36,0:43:42.45,Default,,0000,0000,0010,,{s202}...the temp's gone,\Nthere's no address.
    Dialogue: 0,0:43:42.62,0:43:46.62,Default,,0000,0000,0010,,{s202}I'm talking to some snot-nose lawyer\Nwho's asking me for my badge number.
    Dialogue: 0,0:43:46.79,0:43:48.66,Default,,0000,0000,0010,,{s202}Brick wall.
    Dialogue: 0,0:43:49.54,0:43:53.63,Default,,0000,0000,0010,,{s202}So I take a peek\Ninto Madrigal Electromotive.
    Dialogue: 0,0:43:53.79,0:43:56.38,Default,,0000,0000,0010,,{s202}Now, Madrigal\Nis based in Hanover, Germany...
    Dialogue: 0,0:43:56.55,0:43:59.30,Default,,0000,0000,0010,,{s202}...but they're\Nwhat they call "highly diversified."
    Dialogue: 0,0:43:59.47,0:44:03.26,Default,,0000,0000,0010,,{s202}industrial equipment, global shipping,\Nmajor construction...
    Dialogue: 0,0:44:03.43,0:44:07.72,Default,,0000,0000,0010,,{s202}...and a tiny little foothold\Nin American fast food...
    Dialogue: 0,0:44:07.89,0:44:10.31,Default,,0000,0000,0010,,{s202}...specifically a local chain.
    Dialogue: 0,0:44:10.81,0:44:12.52,Default,,0000,0000,0010,,{s202}Pollos Hermanos.
    Dialogue: 0,0:44:15.77,0:44:18.19,Default,,0000,0000,0010,,{s202}Okay. So what, right?\NBoetticher's dead.
    Dialogue: 0,0:44:18.36,0:44:21.36,Default,,0000,0000,0010,,{s202}I got no line\Non who's been bankrolling him...
    Dialogue: 0,0:44:21.53,0:44:23.45,Default,,0000,0000,0010,,{s202}...or where his lab was.
    Dialogue: 0,0:44:23.61,0:44:25.91,Default,,0000,0000,0010,,{s202}The whole thing's a snipe hunt,\Nright?
    Dialogue: 0,0:44:26.08,0:44:30.16,Default,,0000,0000,0010,,{s202}But now I get this crazy idea...
    Dialogue: 0,0:44:30.66,0:44:32.66,Default,,0000,0000,0010,,{s202}...and I can't shake it.
    Dialogue: 0,0:44:33.12,0:44:36.13,Default,,0000,0000,0010,,{s202}I mean, I stay up nights\Nstaring at the ceiling...
    Dialogue: 0,0:44:36.29,0:44:38.63,Default,,0000,0000,0010,,{s202}...trying to make sense of it.\NThat napkin.
    Dialogue: 0,0:44:38.80,0:44:40.46,Default,,0000,0000,0010,,{s202}I told you Boetticher's vegan.
    Dialogue: 0,0:44:40.63,0:44:44.01,Default,,0000,0000,0010,,{s202}We're talking this guy\Nmakes his own fermented lentil bread...
    Dialogue: 0,0:44:44.18,0:44:46.39,Default,,0000,0000,0010,,{s202}...or whatever the hell that is.
    Dialogue: 0,0:44:47.01,0:44:52.02,Default,,0000,0000,0010,,{s202}What's a vegan doing\Nin a fried chicken joint?
    Dialogue: 0,0:44:55.36,0:44:57.23,Default,,0000,0000,0010,,{s202}Maybe he's meeting somebody.
    Dialogue: 0,0:44:57.40,0:44:59.15,Default,,0000,0000,0010,,{s202}Like who?
    Dialogue: 0,0:44:59.73,0:45:01.82,Default,,0000,0000,0010,,{s202}Well, like, maybe...
    Dialogue: 0,0:45:03.74,0:45:05.49,Default,,0000,0000,0010,,{s202}...this guy.
    Dialogue: 0,0:45:09.66,0:45:12.87,Default,,0000,0000,0010,,{s202}I mean, what do we know\Nabout Gustavo Fring, huh?
    Dialogue: 0,0:45:13.04,0:45:15.42,Default,,0000,0000,0010,,{s202}This whole\Nfriend-of-law-enforcement thing?
    Dialogue: 0,0:45:15.58,0:45:18.75,Default,,0000,0000,0010,,{s202}Could be a case of, "keep your\Nfriends close but your enemies closer."
    Dialogue: 0,0:45:18.92,0:45:21.00,Default,,0000,0000,0010,,{s202}He's got the money\Nto finance this operation.
    Dialogue: 0,0:45:21.17,0:45:24.93,Default,,0000,0000,0010,,{s202}Maybe he's got the connections too.\NMaybe, just maybe...
    Dialogue: 0,0:45:25.55,0:45:26.76,Default,,0000,0000,0010,,{s202}...he's our guy.
    Dialogue: 0,0:45:31.02,0:45:34.73,Default,,0000,0000,0010,,{s202}Hank, no offense,\Nbut I think you're really reaching.
    Dialogue: 0,0:45:34.89,0:45:38.19,Default,,0000,0000,0010,,{s202}If your guy had his meeting at KFC...
    Dialogue: 0,0:45:38.36,0:45:42.40,Default,,0000,0000,0010,,{s202}...you wouldn't immediately assume\Nhe's sitting down with Colonel Sanders.
    Dialogue: 0,0:45:42.57,0:45:44.28,Default,,0000,0000,0010,,{s202}You know, I...
    Dialogue: 0,0:45:44.78,0:45:47.07,Default,,0000,0000,0010,,{s202}I couldn't agree more, guys.
    Dialogue: 0,0:45:47.95,0:45:52.04,Default,,0000,0000,0010,,{s202}Gustavo Fring, blue meth, you know.
    Dialogue: 0,0:45:52.45,0:45:57.08,Default,,0000,0000,0010,,{s202}The whole thing is off-the-map nuts.
    Dialogue: 0,0:45:57.54,0:46:00.50,Default,,0000,0000,0010,,{s202}I ought to be wearing a tinfoil hat,\Nyou know?
    Dialogue: 0,0:46:02.09,0:46:03.80,Default,,0000,0000,0010,,{s202}Except...
    Dialogue: 0,0:46:05.01,0:46:08.84,Default,,0000,0000,0010,,{s202}...I can't seem to wrap my mind\Naround this one little thing...
    Dialogue: 0,0:46:09.01,0:46:13.97,Default,,0000,0000,0010,,{s202}...and that is,\Nwhat are Gustavo Fring's fingerprints...
    Dialogue: 0,0:46:14.98,0:46:17.60,Default,,0000,0000,0010,,{s202}...doing\Nin Gale Boetticher's apartment?
    Dialogue: 0,0:46:21.00,0:46:26.24,Default,,0000,0000,0010,,{s202}Subs collected, corrected and if necessary re-synced by Tronar for\N"Breaking Bad Season 1, 2, 3, 4 & 5 + Extras BDRip DVDRip HDTV TSV"
    Windows 10, MPC-BE
    Jul 2011
    Denmark
    You can try in SE via Edit -> Multiple replace, with a regex like "[.\s\S]*BDRip DVDRip HDTV[.\s\S]*" - should remove first and last line
  16. ^.*Subs collected.*
  17. Teodz- that seems to only remove the part where it says Subs collected, doesn't remove the whole line.
    Nikse- thanks this works. Still have to do this manually for every file rather than a batch file edit. But it's still faster than what I was doing before.
    Windows 10, MPC-BE
  18. https://files.videohelp.com/u/176692/Dialogue.jpgWorks on my end
    The problem is because that line is too long 140 characters long...
    Just use the editor and edit out the text manually
