Results 1 to 16 of 16
  1. I have written a program to extract a frame of YUV video using ffmpeg.
    If the video comes directly from a camcorder, all of the Y, U and V values are set to 0.
    If the video file has been rewritten using, say, ffmpeg, the video appears normally using the exact same code. The video files are .mp4 with H.264. All video plays back OK using any video player program.
    Here is the code that reads the video frames into the program:
    pipeIn$ = "-i " + filename$ + " -f image2pipe  -s 1280x720  -pix_fmt yuv420p  -vcodec rawvideo -"
    readFrame = RunProgram("ffmpeg.exe", pipeIn$, "", #PB_Program_Open | #PB_Program_Read)
    My program is written in PureBasic, based on a C language program.
    https://batchloaf.wordpress.com/2017/02/12/a-simple-way-to-read-and-write-audio-and-vi...-part-2-video/
    Why do some files work OK and others not?
  2. What are the other differences between the videos that work , and the ones that do not ? Are both MP4 with h264 video ?
    Could it be something simple like path error, or filename error ?
    What do mean "rewritten" ? Stream copy ? Re-encode ?
  3. What are the other differences between the videos that work , and the ones that do not ? Are both MP4 with h264 video ?
    Yes, both are .mp4 with H.264 video as far as I can tell. The only difference I can discern is one is directly out of the camcorder and the other has been re-encoded.
    Re-encoded, e.g.
    ffmpeg -y  -i  myvideo.mp4  myoutvideo.mp4
    I would like to be able to read the camcorder file directly, without the re-encoding step.
  4. Directly out? Is the camcorder file copied to a local HDD ? or still in the camcorder / media card ?
    What does mediainfo (view=>text) say about the camcorder file ?
    What about stream copying the file? ( -c:v copy ) . Does that work ?
    All camcorder files, or only from that specific camcorder ? or only specific files ?
  5. The files are transferred from the camcorder to a local HD via a USB connection.
    It happens with both a Sony and a Canon camcorder.
    There is a lot of stuff in MediaInfo which I don't know how to interpret, so here they are:
    Re-encoded with ffmpeg:
    General
    Complete name                            : D:\Videos\Interpositives\fixed.mp4
    Format profile                           : Base Media
    Codec ID                                 : isom (isom/iso2/avc1/mp41)
    File size                                : 1.25 MiB
    Duration                                 : 12 s 523 ms
    Overall bit rate                         : 837 kb/s
    Writing application                      : Lavf58.33.100
    Video
    Format profile                           : High@L3.2
    Format settings                          : CABAC / 4 Ref Frames
    Format settings, Reference frames        : 4 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Duration                                 : 12 s 513 ms
    Bit rate                                 : 692 kb/s
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 59.940 (60000/1001) FPS
    Bits/(Pixel*Frame)                       : 0.013
    Stream size                              : 1.03 MiB (83%)
    Writing library                          : x264 core 158
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language                                 : English
    Codec configuration box                  : avcC
    Audio
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Codec ID                                 : mp4a-40-2
    Bit rate mode                            : Constant
    Bit rate                                 : 132 kb/s
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Stream size                              : 201 KiB (16%)
    Language                                 : English
    Default                                  : Yes
    Alternate group                          : 1
    Other
    Type                                     : Time code
    Format                                   : QuickTime TC
    Time code of first frame                 : 00:38:44;20
    Time code, striped                       : Yes
    Language                                 : English
    Default                                  : No
    Directly out of Canon HF G40 Camcorder:
    General
    Complete name                            : D:\Videos\Canon Vixia HF G40\VelvetSharpLo.MP4
    Format profile                           : Base Media / Version 2
    Codec ID                                 : mp42 (mp42/avc1/CAEP)
    File size                                : 11.9 MiB
    Overall bit rate                         : 7 958 kb/s
    Encoded date                             : UTC 2018-05-09 13:22:34
    Tagged date                              : UTC 2018-05-09 13:22:34
    Video
    Format profile                           : Main@L3.2
    Format settings                          : CABAC / 2 Ref Frames
    Format settings, Reference frames        : 2 frames
    Format settings, GOP                     : M=3, N=30
    Codec ID                                 : avc1
    Bit rate                                 : 7 656 kb/s
    Height                                   : 720 pixels
    Bits/(Pixel*Frame)                       : 0.139
    Stream size                              : 11.4 MiB (96%)
    Language                                 : English
    Color range                              : Limited
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : AAC LC
    Duration                                 : 12 s 501 ms
    Bit rate                                 : 128 kb/s
    Stream size                              : 195 KiB (2%)
    Language                                 : English
    Other
    Type                                     : Time code
    Language                                 : English
  6. I don't know . Nothing there jumps out as the culprit. If it works for the reencoded one, it should work for the source.
    One difference is the subset of MP4 container. mp42 vs. isom mp41 . Earlier I asked you to stream copy and test that. Rewrap it using the default ffmpeg mp4 muxer profile (isom mp41) . In theory it shouldn't make a difference. If it works, at least the values read off will be accurate, instead of a lossy re-encode. Steam copy will also be faster and much smaller than a lossless re-encode
  7. It works OK with -c:v copy
    General
    Complete name                            : D:\Videos\Interpositives\streamed.mp4
    File size                                : 11.6 MiB
    Overall bit rate                         : 7 795 kb/s
    Video
    Codec ID                                 : avc1
    Height                                   : 720 pixels
    Stream size                              : 11.4 MiB (98%)
    Language                                 : English
    Audio
    Format                                   : AAC LC
    Bit rate                                 : 132 kb/s
    Stream size                              : 201 KiB (2%)
    Language                                 : English
    Default                                  : Yes
    Alternate group                          : 1
    Other
    Type                                     : Time code
    Language                                 : English
    Default                                  : No
  8. Originally Posted by chris319 View Post
    Completely unexpected.
    FFmpeg can read the native camera file, it should be able to pipe it . The container should have nothing to do with it at that point
    If the program is giving off values at "zero" , that's more like it's not reading the file at all . Are there error codes or other clues ?
  9. No error codes.
    Why would it work OK on some files but not others?
    The original camcorder footage plays OK in any video player.
  10. Originally Posted by chris319 View Post
    I don't know. It doesn't make any sense. It sounds like the original footage is ok - I doubt that is the problem
    The one difference is the mp4 container. mp42 (mp4 v2) is a newer profile, but it shouldn't matter. You stream copied it out of that container into the older MP4 profile container and reported that worked. That's the only tangible difference I can see. But once ffmpeg reads it, it pipes the rawvideo data . It obviously can read it from any container variation (including mp42) - other wise you couldn't have re-encoded the original.
    The other possible explanation is something simple, like a path or name error.
  11. If it were a path or name error it wouldn't be able to read the files it does.
  12. Are you sure it's reading it when giving off "zero" ?
    The paths and names are obviously different on the files that work. The ones in the "Interpositives" folder work
  13. Checked the file names/paths; no problems found.
  14. Problem solved:
    Had to remove all spaces from directory names. The program was not finding the files and was trying to load blanks.
  15. Spaces should work if you enclose path and names in quotes
  16. Originally Posted by poisondeathray View Post
    Yes, that works very nicely, thank you.
