    Nov 2019
    London UK
    Can anyone advise on what type of connector this Sanyo video cam used on the bottom of its camera adapter. Its got a standard USB connector on one end, an inductor to reduce interference towards one end but the camera end is a tiny almost square connector (definitely not one of the standard USBs). It has 8 conectors (4 x2 rows). Later VPC Sanyop models did switch to a more normal micro/mini USB. Any help appreciated
  2. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Picture?
    Feb 2006
    Nov 2019
    London UK
    Have attached picture of the "dedicated USB cable" - at least i know what its formally described as. Unfortunately finding one is still proving difficult. Have attached 2 pictures
Name:	New Image.JPG
    Nov 2019
    London UK
    Hiya very close but not the same. The Sanyo is a nearly square (actually a rectangle) with a small location slot. The Nikon appears to have a similar slot but also a raise nose beside the slot. Going to buy one and grind the nose away. Would love to hear from anyone who knows a supplier of the correct cable though, Julian
  6. Capturing Memories dellsam34's Avatar
    Jan 2016
    I got two of these, one with a bigger body, look at the picture and see which one you want I will send it to you at no cost if you are in the US. just PM me your address.
