Page 3 of 3
FirstFirst 1 2 3
Results 61 to 68 of 68
  1. Originally Posted by non-vol View Post
    Why would 2 bytes be used for 10 bit values?
    You might be right, I simply assumed, memory allocates 32bit chunks with four bytes. But maybe three 10bit values could be allocated in 32bit chunk, or something similar somehow, not sure on that one. I just remember Vapoursynth's author mentioned that if data was something between 8 bit and 16bit is a waste of memory (assuming it allocates 16bit for 9bit to 16bit). But that would be uncompressed planes and particular software.
  2. Originally Posted by non-vol View Post
    Thanks. Although I was more trying to point out that while chroma subsampling and colorspace conversions have been explained in excruciating and excessive detail, with several example pictures and diagrams... the "actual compression" has not.
    And if you read through the links, and the articles they link to, you'll have excruciating and excessive detail to wade through.
    Nov 2019
    Europe
    Are you talking about processing or storage? Modern computers work with 64 bit data internally, but you can store a stream of 9-bit values on your hard drive if you want to. And you would if you don't want to waste space.
    Nov 2019
    Europe
    Do they also have have the extremely helpful example pictures and diagrams that make it all easy to understand?
  5. Originally Posted by non-vol View Post
    Yes, the do.
  6. Originally Posted by non-vol View Post
    Yes, the do. Though "easy" is a relative term.
    Nov 2019
    Europe
    You're right.
    Seriously though, what would be useful was a simplified and condensed version of what x265 does. In visual, not so much technical terms. Pictures, not words (the subject is video compression after all). I don't know if anything like this exists.
  8. you can take a mp4 or mov file, choose number of generation copies in the script below to see it for yourself:
    dependencies: python 3.6 or above, vapoursynth, x265, mp4box
    #Python3.6 or above
    loads source video file (mp4 or mov) and creates number of copies
    where each copy is made from previous copy
    effectively getting 'x' generation copy for study generation loss for x265
    use as vapoursynth script or run python in cmd prompt:
    python "generation_copy.py" 10 "F:/_lighthouse_lossless.mp4"
    using mp4box, x265 and vapoursynth python module
    import vapoursynth as vs
    from vapoursynth import core
    import subprocess
    import shutil
    import os
    import sys
    core.max_cache_size = 800  #comment it out if having plenty of RAM
    cwd = os.getcwd()          #current working directory
    TEMP_DIR = cwd
    OUTPUT_DIR = cwd           #or select some:  OUTPUT_DIR = r'E:\some_dir'
    MP4BOX, X265 = None, None
    #MP4BOX = shutil.which('Mp4box') #windows,  mp4box.exe must be in working directory or in PATH
    #MP4BOX = shutil.which('MP4box') #linux , I have it there with uppercase "P" after installing
    MP4BOX = r'C:\tools\MP4box-64bit\mp4box.exe'  #win , manualy giving PATH
    X265 = shutil.which('x265')    #x265.exe must be in working directory or in PATH
    for executable, path in dict(Mp4box=MP4BOX, x265=X265).items():
        if not path:
            raise FileNotFoundError(f'{executable} executable was not found, should be in working directory or in the path,'
               '\nif using vsedit, working directory is directory  where this script is saved')
        elif not os.path.isfile(path):
            raise FileNotFoundError(f'{executable} executable is not a file, check for errors in a path string')
        elif not os.access(path, os.X_OK):
            raise FileNotFoundError(f'no administrative rights to run {executable} executable')
    def stdin_frames(current, total):
        print(f'{current} of {total}')
    def encode_copy(index, file_path):
        temp_output = os.path.join(TEMP_DIR, 'temp.hevc')  #mp4box does not support stdin
        new_path = os.path.join(OUTPUT_DIR, f'copy_{index}.mp4')
        #make vapoursynth clip
        clip = core.lsmas.LibavSMASHSource(file_path)
        if index == 1:
            #some filtering, slicing, crop could be applied to source clip only
            #clip = clip[0:50]
            #clip = core.std.CropAbs(clip, width=538, height=446, left=64, top=50)
            pass
        #encode HEVC
        print(f'encoding {index} of {NUMBER_OF_COPIES},  {new_path}')
        x265_cmd = [X265,
                 '--frames', f'{len(clip)}',
                 '--y4m',
                 '--input-depth', f'{clip.format.bits_per_sample}',
                 '--output-depth', '10',
                 '--input-res', f'{clip.width}x{clip.height}',
                 '--fps', f'{clip.fps_num}/{clip.fps_den}',
                 '--crf',    '18',
                 '--output', temp_output,
        process = subprocess.Popen(x265_cmd, stdin=subprocess.PIPE)
        clip.output(process.stdin, y4m = True) #progress_update=stdin_frames
        process.communicate()
        #muxing hevc stream to mp4
        print(f'muxing {index} of {NUMBER_OF_COPIES},  {new_path}')
        fps = f'{str(clip.fps_num/clip.fps_den)}'
        mp4box_cmd = [MP4BOX,
                     '-add' , temp_output+f':fps={fps}',
                     '-par', '1=1:1',
                     '-new',  new_path]
        process = subprocess.Popen(mp4box_cmd)
        #delete temp
        if os.path.exists(temp_output):   os.remove(temp_output)
        return new_path
    def run():
        new_path = SOURCE
        for index in range(1, NUMBER_OF_COPIES+1):
            new_path = encode_copy(index, new_path)
    if __name__ == "__main__" and not len(sys.argv) == 1:
        running python script in command line:
        NUMBER_OF_COPIES = int(sys.argv[1])
        SOURCE = sys.argv[2]
        run()
    elif __name__ == "__vapoursynth__" or len(sys.argv) == 1:
        this runs as vapoursynth script or if executing this script without arguments (in python console)
        it can be used using vspipe as well, example:
        "vspipe.exe" "gereration_copy.py" .
        or
        "vspipe.exe" "gereration_copy.vpy" .
        NUMBER_OF_COPIES = 10   #1 or more
        SOURCE = r'F:/_lighthouse_lossless.mp4'
        run()
