When I check the MTS files that my Canon camcorder records in Mediainfo, I can see that in the Audio info it is written in case of every of them: "Delay relative to video: -80ms"
You can see a screenshot here about this: https://postimg.cc/pyf8VT3Y
In case I import these files to Sony Vegas, will Vegas adjust the delay automatically and place the audio and video correctly on the timeline, or after adding the video to the timeline, I should shift the audio manually with 80 ms?
Most likely you are trying to fix something that isn't broken.
Look for a clear sync moment -- say, a close handclap and see if sound and picture are in sync. If it's 2-3 frames off, consider making the adjustment.
On my Sony CX900, audio on spanned clips start with a whopping -445ms delay (after the first clip) -- and the sync is dead on.Last edited by smrpix; 1st Nov 2019 at 09:44.
Camcorder fell – trying to properly import MTS clip without metadata
By abolibibelot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 2nd Oct 2019, 17:01 -
Sony Vegas 13 only importing audio and no video
By OmegaAlphaGaming in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2016, 10:45 -
Sony Vegas - Strange problem with Sony AVC/MVC rendered files
By RMCF10 in forum Newbie / General discussionsReplies: 16Last Post: 5th Feb 2016, 05:04 -
Unable to import mp4 videos in sony vegas pro 13.Only audio out of video.
By WingSaber in forum Capturing and VCRReplies: 1Last Post: 12th Jul 2015, 16:56 -
Hourglass delay when accessing video files in Vegas Pro 9
By brassplyer in forum EditingReplies: 0Last Post: 30th Mar 2015, 08:09
