Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Jul 2017
    Los Angeles
    Hello folks,
    I have a mini-DV camcorder that still works great and from which I have a lot of video to capture.
    I also have a Windows 10 workstation with FW800 ports.
    Are there any software offerings out there that will still "see" this camcorder and be able to capture my video clips?
    Thanks in advance...
    Keith
  2. HDVSplit , there is one reviewer on that download page that uses win10
    Jul 2017
    Los Angeles
    I am not familiar with that. Is that a program that comes with a Windows install??
  4. Click that link in my post, download it, that 0.77 version , portable (it's beta but it is ok) , run.
    Jul 2017
    Los Angeles
    wow, alright,... thank you
    Oct 2018
    Gillette Stadium, United States
    HDV split is THE capture utility for HDV.
    The Canon HV-30 (I still have mine), is a great camera and takes video that looks rather film-like.
    If you run into trouble I will see if it works on my latest W10 install, it's been a while since I used it.
  7. Preservationist davideck's Avatar
    Feb 2003
    USA
    HDV split works fine with my HV-30 and Windows 10 version 1903.
    Life is better when you focus on the signals instead of the noise.
    Jul 2017
    Los Angeles
    Thanks again folks. This may save me having to try to resurrect my 9yo MacBook Pro.
    ~ Keith
