Results 1 to 12 of 12
  1. I used TEncoder about 6 months ago to change the audio codec on four x265 movies, setting the video codec to Direct Copy. It worked flawlessly. The output was an x265 video with zero quality loss and a different audio codec in perfect sync with the video. I tried to use it the same way yesterday and now, even on Direct Copy of the video, the conversion file has sound only, no video. If I start over and click "Preview", the app freezes. It seems to work ok on files with other video codecs like mp4. The problem seems to be with x265, even on Direct Copy of video. Other apps, like VLC, will play the x265 files fine on my PC. Does anyone have any ideas on what has changed, either in the app, settings, or my PC? Thanks in advance for any advice.
  2. I meant it works fine with x264 codec.
    Aug 2013
    Central Germany
    That is indeed strange. How did you discover that there is no video stream? Did you use MediaInfo (maybe MediaInfo.NET as GUI now)? If there is really no video stream included, how could VLC play the result?
    Can you provide some screenshots of your workflow and a few small samples (before/after)?
  4. I'll rephrase it. The video is already x265 and I want to change the audio codec. The x265 file, before conversion, plays fine with VLC and also Media Player Classic on my PC. Then I use TEncoder. TEncoder accepts the file, I set the video codec at "Direct Copy" and choose the audio codec, and choose FFMpeg as the encoder . TEncoder goes through the conversion process, but the resulting file plays a converted audio stream but no video stream. If I start over and set things as before, and before I start the conversion I select "Preview", then TEncoder freezes. However, 6 months ago it worked perfectly. I am still using the same Win 7 PC. I use TEncoder 64 bit portable. I also tried older versions and the 32 bit version, all behave exactly the same. I just ran MediaInfo, it reports there is a converted video stream giving the results I expect, 59.94 FPS, HEVC, 1920x1080, 2hr 18min, 1.86G file size. However this converted file will not play in VLC (or Media Player Classic). MPC reports an error, I am attaching the MPC report.
    Aug 2013
    Central Germany
    It seems that this conversion did not produce any recognized container. Did you select any target container in TEncoder? Also, which is your target audio codec?
    It would be useful to see an extended MediaInfo report (you could use MediaInfo.NET by stax76 as GUI), or have two small sample files (original and converted).
  6. Here are the mediainfo results.The first one, mi.txt, which says "Opus" in the complete name, is the unconverted file that plays fine. The second one, mi2.txt, has AAC in the complete name, and is the one giving the video problem. Hope they tell you something. I sincerely appreciate your help.
  7. That is, mi2.txt is the converted file with TEncode, which has the video codec as "Direct Copy". The container is mkv, but changing it to mp4 didn't make a difference.
    Mar 2008
    Have you tried opening the file in Graphstudio? Do you get a valid graph and does it play?
  9. I just tried Graaphstudio as suggested. The converted file does not give a graph, just one square with the file name and it does not play. The unconverted original does show a graph and does play
    Mar 2008
    Have you tried remuxing the file in MKVtoolnix and see if the resultant file works?
    If not, perhaps you can provide a small sample for the forum to investigate
    Perhaps you should check the log. I downloaded Tencoder and tried the x265 > copy, vorbis > aac and it worked OK
    here's my log
    Encoder 1 log
    Encoder 1 command lines:
     -y  -itsoffset 0 -threads 4  -i "F:\Documents and Settings\Dave Xnet\Desktop\Dave video shortcuts\x265Beatles Blackpool 1965\I Feel Fine (Blackpool).mkv"     -c:v copy  -map 0:0 -map 0:1  -strict experimental -c:a aac -ab 128k  -af aresample=resampler=soxr -ar 44100 -ac 2    "F:\Documents and Settings\Dave Xnet\Desktop\Dave video shortcuts\tenc\x265Beatles Blackpool 1965\I Feel Fine (Blackpool).mkv"
    Encoder 1 console outputs:
    ffmpeg version N-76860-g72eaf72 Copyright (c) 2000-2015 the FFmpeg developers
      built with gcc 5.2.0 (GCC)
      configuration: --disable-static --enable-shared --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib
      libavutil      55.  9.100 / 55.  9.100
      libavcodec     57. 16.100 / 57. 16.100
      libavformat    57. 19.100 / 57. 19.100
      libavdevice    57.  0.100 / 57.  0.100
      libavfilter     6. 15.100 /  6. 15.100
      libswscale      4.  0.100 /  4.  0.100
      libswresample   2.  0.101 /  2.  0.101
      libpostproc    54.  0.100 / 54.  0.100
    Input #0, matroska,webm, from 'F:\Documents and Settings\Dave Xnet\Desktop\Dave video shortcuts\x265Beatles Blackpool 1965\I Feel Fine (Blackpool).mkv':
      Metadata:
        COMPATIBLE_BRANDS: isomavc1mp42
        MAJOR_BRAND     : mp42
        MINOR_VERSION   : 0
        ENCODER         : Lavf57.19.100
      Duration: 00:02:37.99, start: 0.000000, bitrate: 619 kb/s
        Stream #0:0: Video: hevc (Main), yuv420p(tv), 352x288 [SAR 12:11 DAR 4:3], 24.99 fps, 24.99 tbr, 1k tbn, 24.99 tbc (default)
        Metadata:
          CREATION_TIME   : 2008-10-20 03:44:28
          HANDLER_NAME    : (C) 2007 Google Inc. v08.13.2007.
          ENCODER         : Lavc57.16.100 libx265
          DURATION        : 00:02:37.565000000
        Stream #0:1: Audio: vorbis, 44100 Hz, stereo, fltp (default)
        Metadata:
          ENCODER         : Lavc57.16.100 libvorbis
          DURATION        : 00:02:37.991000000
    [matroska @ 018f7020] Codec for stream 0 does not use global headers but container format requires global headers
    Output #0, matroska, to 'F:\Documents and Settings\Dave Xnet\Desktop\Dave video shortcuts\tenc\x265Beatles Blackpool 1965\I Feel Fine (Blackpool).mkv':
      Metadata:
        MAJOR_BRAND     : mp42
        MINOR_VERSION   : 0
        encoder         : Lavf57.19.100
        Stream #0:0: Video: hevc, yuv420p, 352x288 [SAR 12:11 DAR 4:3], q=2-31, 24.99 fps, 24.99 tbr, 1k tbn, 1k tbc (default)
        Metadata:
        Stream #0:1: Audio: aac ([255][0][0][0] / 0x00FF), 44100 Hz, stereo, fltp, 128 kb/s (default)
        Metadata:
          encoder         : Lavc57.16.100 aac
    Stream mapping:
      Stream #0:0 -> #0:0 (copy)
      Stream #0:1 -> #0:1 (vorbis (native) -> aac (native))
    Press [q] to stop, [?] for help
    frame= 3937 fps=252 q=-1.0 Lsize=   12423kB time=00:02:38.01 bitrate= 644.1kbits/s
    video:9879kB audio:2468kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.621767%
    [aac @ 0190ac20] Qavg: 660.653
  11. It doesn't run. Here is the MKVToolNix output.
    I have a second HD on my PC with Win XP on it and nothing else installed. I ran the 32 bit portable version of TEncoder and it did exactly the same thing. Is there any setting I could have wrong? I'm doing Direct Copy, AAC audio, FFMped encoder, and same video size and aspect ratio in the options, although with Direct Copy i don't why that would matter. I tried mkv and mp4 containers.
  12. matroska @ 018f7020] Codec for stream 0 does not use global headers but container format requires global headers
    I've seen such problems happen when people used old experimental mkvtoolnix versions ("Rovi"/DivX) to mux HEVC. I don't know if it's possible to repair such files. Not sure what to tell you except: don't use deprecated software. (You can still try to mux video from original file to audio encode from TEncoder using recent mkvtoolnix. File may still work in some error resilient players despite being broken, then.)
    On top of that there is the error message from mkvmerge. Those I've seen happen when files become corrupted (e.g. hardware errors from RAM or buggy USB).
    So there may be multiple problems with the files.
