Hello, it's my first post on the site, I'm following the site for a long time, but it is first time i registered and posted.
So first time i got confused, i got a 4K bdremux .mkv movie and it has 2 video in it, one is 4k another one 1080p resolution. My question is, if i remux it with 4k resolution one do i lose any quality or what is exactly?
Thanks in advance
Closed Thread
To get the details, open the file in mediainfo, put it text view, and copy and paste the info here
General
Complete name : F:\Transformers\Bumblebee.2018.UHD.BDRemux.2160p.D V.IVA.(RUS.UKR.ENG).ExKinoRay\BDMV\STREAM\00000.m2 ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 52.6 GiB
Duration : 1 h 53 min
Overall bit rate : 66.2 Mb/s
Maximum Overall bit rate : 109 Mb/s
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Video #2
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Audio #1
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 129
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 521 MiB (1%)
Service kind : Complete Main
Audio #2
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 192 kb/s
Channel(s) : 2 channels
Stream size : 156 MiB (0%)
Audio #3
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate mode : Variable
Bit rate : 640 kb/s
Maximum bit rate : 7 761 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #4
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 640 kb/s
Text #1
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #2
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #3
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #4
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Converting a 1080p 60Hz to 1080p 23.97Hz
By snadge in forum Video ConversionReplies: 3Last Post: 11th Sep 2019, 11:31 -
Remux of a Blu-day video playbacks poorly (using tsMixer)
By HE1NZ in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2019, 19:59 -
Looking to make BluRay video from 1080p/60fps video shot on Sony NX100 cam
By liberty610 in forum Authoring (Blu-ray)Replies: 38Last Post: 26th Sep 2018, 20:13 -
Mass convert multi 1080p BluRay REMUX AVC to multi 1080p hdlight
By levi59 in forum Newbie / General discussionsReplies: 5Last Post: 17th Dec 2017, 16:43 -
1080p 25fps (PAL) to 1080p NTSC?
By digitalfreaknyc in forum Video ConversionReplies: 38Last Post: 31st Mar 2016, 00:04
