Results 1 to 11 of 11
  1. I have a Plex Media Server at my home which I use to watch movies on tablets in my home wifi network. My TV is also connected to the Internet via Wifi. I live in a house with about 3500 sq feet. I want to upgrade my Wifi Router to get the fastest and best performance out of watching videos and/or TV, avoiding slow downs or dead zones. What is the best Wifi router available today for viewing TV and videos on a home network?
    Thanks in advance!!
    Dave
  2. https://www.forbes.com/sites/anthonykarcz/2019/07/05/the-best-routers-for-large-houses/#1e7a5ea63fb0
  3. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    It would be much better if you just had at least one ethernet backbone going from one end of the house to the other, and have two or more wifi routers connected together which can then operate on different channels.
  4. Thank you KarMa!
  5. none of mentioned in article - go for 802.11ax technology routers - something certified for WiFi6 https://www.wi-fi.org/product-finder-results?sort_by=certified&sort_order=desc&capabilities=17
    This one looks promising: https://www.buffalo.jp/product/detail/wxr-5950ax12.html sadly to say it is currently available on Japanese market but i would expect soon more similar devices on US and European markets. 8x8 configuration with beamforming may efficiently double real life performance.
    In approximation doubling number of antennas will increase your range by 2 - of course using WiFi extenders may improve coverage but usually at a cost of doubling latency and reducing overall throughput by half.
  6. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    A much faster/easier alternative than installing ethernet in the walls would be using an ethernet powerline adapter (need 2). Which simply uses your electrical house wiring as a medium to transmit data. They can usually provide between 100Mbit to a 1000Mbit.
  7. Thank you very much!
    Aug 2004
    PA USA
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
  9. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Been very happy with tp-link routers. If I need more coverage I run a cable to a 2nd one or do powerline adaptors to 2nd one and set it to access point mode.
    if all else fails read the manual
  10. Originally Posted by sum_guy View Post
    Nothing can match 802.11ax
    https://www.yodobashi.com/product/100000001005129594/
    But read before buying https://www.smallnetbuilder.com/wireless/wireless-features/33209-5-things-to-know-befo...ft-11ax-router
    And perhaps wait few months...
    Beamforming with 8 antennas can increase range more than twice... and this can be used with ac not only ax STA.
