I've been using MeGUI to do these remuxes for years, but it takes more steps than i would like as i have to extract and then encode and then mux into mkv/mp4. I found Box4 the other day, but it has some issues with audio being out of sync after encoding it sometimes. I try the same file in MeGUI and it outputs fine with no sync issues.
Are there any other programs for this? I've messed with VideoReDo a little bit, but it seems to mess up playback a little bit in VLC. So that the time line doesn't work properly. So would kind of like to stay away from that.
Are there any other programs like Box4? I really like how easy and fast the UI is and if it didn't have sync issues that might have been my go to program to replace MeGUI.
You could also try myFFmpeg (shareware $20, 32 or 64 bit) which is a GUI for FFMPEG. It makes FFMPEG much easier to use and will remux between containers, or reencode only the audio and pass-through the video untouched to remux to a new container (and vice-versa), hard-code or soft-code subtitles. Worth a look.
Strange. It's OOS using ffmpeg as well. It seems to only be out of sync in Adobe Premiere though... seems to be in sync using VLC. What does MeGUI do differently? It's doing pretty much the same thing. Directly remuxing the video and encoding audio to AC3. It's perfect in both VLC and Adobe Premiere using MeGUI, but it's OOS in Adobe Premiere using ffmpeg and box4.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
Program that will remux MKV, FLV, and AVI to MP4
By 90sTV in forum MacReplies: 5Last Post: 18th Apr 2019, 17:33 -
no audio after converting MKV to MP4
By Frustrated Geezer in forum Newbie / General discussionsReplies: 7Last Post: 29th Sep 2017, 06:32 -
Best Program for MKV to MP4 Conversion -- NO quality loss?
By xxevilxp3nrxx in forum Video ConversionReplies: 13Last Post: 13th Aug 2015, 02:47 -
What program can batch convert JUST audio of .mp4 files then re-mux?
By Whitezombie455 in forum Video ConversionReplies: 18Last Post: 25th Jan 2015, 09:36
