What setting do I use in TMPGEnc (4:3. 16:9 4:3 display, 16:9 display, etc.) when I want to encode a DVD that originally was in widescreen format and I want to play a VCD of it in widescreen on a 4:3 NTSC screen?
Also, since I'm here, how do you transfer chapters for the second half of a movie if you're using Chapter X-tractor and VCD Easy?
for your 1st question, I just answered almost the same question here:
http://forum.vcdhelp.com/viewtopic.php?t=89525
Sorry, cant help with the other one tho -
output video should be 4:3 NTSC
as for source aspect ratio ... asuming u ripping region 1 NTSC dvds ... you're gonna need dvd2avi to tell u what the source aspect ratio is....when u load the vob files and are creating the project file, it will tell u whether the source is 16:9 or 4:3
since you're ripping region 1 NTSC dvds, source aspect ratio in tmpgec will be either (16:9 525 line NTSC) or (4:3 525 line NTSC)
as for image positioning method, choose full screen (preserve aspect ratio)
Convert from .rm format without re-encoding
By pmennen in forum Video ConversionReplies: 18Last Post: 1st Apr 2012, 04:59 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
What format for encoding to get both Audio and Video tracks?
By DaveFresco in forum Video ConversionReplies: 3Last Post: 2nd Jun 2010, 02:48 -
Universal encoding for random format videos ??
By lostnucleus in forum ffmpegX general discussionReplies: 3Last Post: 19th Oct 2009, 08:33 -
Professional online encoding to flash format
By Ogilvy in forum Video ConversionReplies: 4Last Post: 17th Jan 2008, 18:45
