  1. Hi everybody,
    does ffmpeg supports trimming of a online video content?
    I.e. if I want to trim and download only a certain part of a online video content, instead of downloading the entire video.
    Thank you
  2. start at: -ss HH:MM:SS.ddd
    length: -t HH:MM:SS.ddd
  3. Originally Posted by jagabo View Post
    Can you please give an example, let's say for this video:
    HTML Code:
    https://www.youtube.com/watch?v=7OoMo-Y4wus&list=PLRdw3IjKY2gn5PsvNGb9bjrVDbQCcljM8
  4. Ok, i figure it out. Thank you
  5. Post your solution for the next guy...
  6. Originally Posted by jagabo View Post
    1. In ffmpeg: youtube-dl -g "YOUR YOUTUBE LINK"
    Ffmpeg will find 2 links, 1 for audio, 1 for video.
    2. Copy and paste in the following command:
    ffmpeg -ss 27:11 -i "FIRST LINK" -ss 27:11 -i "SECOND LINK" -map 0:v -map 1:a -t 0:08 -c:v libx264 -c:a aac FILENAME.mkv
    -ss is starting point of the video and audio links (in this case 27:11) and -t is how many seconds/minutes/hours to cut from -ss (in this case 8 seconds)
    FULL EXAMPLE:
    ffmpeg -ss 27:11 -i "https://r11---sn-xupn5a5u-4wgel.googlevideo.com/videoplayback?expire=1572114795&ei=Cz20XeTrOMSQmLAP2LejqA0&ip=86.99.150.133&id=o-AISUxSib01Skhl14Rdd7ivzqgGlQcn7RsXlT83ynNiw5&itag=136&aitags=133%2C134%2C135%2C136%2C160%2C242%2C243%2C244%2C247%2C278&source=youtube&requiressl=yes&mm=31%2C26&mn=sn-xupn5a5u-4wgel%2Csn-5hne6nsk&ms=au%2Conr&mv=m&mvi=10&nh=EAI%2C&pl=21&gcr=ae&initcwndbps=668750&mime=video%2Fmp4&gir=yes&clen=1839679563&dur=8187.947&lmt=1571691841189608&mt=1572093104&fvip=2&keepalive=yes&fexp=23842630&c=WEB&txp=5432432&sparams=expire%2Cei%2Cip%2Cid%2Caitags%2Csource%2Crequiressl%2Cgcr%2Cmime%2Cgir%2Cclen%2Cdur%2Clmt&sig=ALgxI2wwRgIhANrcE_XuF1W_CVqmf3tpUeVrDFJGs1m1jtED_7gAUEwBAiEAtAiNgw7MhY5Ng92Iu_nfmSU1_idwdOBpei3yIg_SC-U%3D&lsparams=mm%2Cmn%2Cms%2Cmv%2Cmvi%2Cnh%2Cpl%2Cinitcwndbps&lsig=AHylml4wRgIhANmfZsBSjq3pgIj_GENEGCwlOzTTg_UdNEBiFzb-_bYFAiEAnfRO2gAzNLx5P7eMgCOlNrPyRX5msEpv-B6eygddJoo%3D&ratebypass=yes" -ss 27:11 -i "https://r11---sn-xupn5a5u-4wgel.googlevideo.com/videoplayback?expire=1572114795&ei=Cz20XeTrOMSQmLAP2LejqA0&ip=86.99.150.133&id=o-AISUxSib01Skhl14Rdd7ivzqgGlQcn7RsXlT83ynNiw5&itag=251&source=youtube&requiressl=yes&mm=31%2C26&mn=sn-xupn5a5u-4wgel%2Csn-5hne6nsk&ms=au%2Conr&mv=m&mvi=10&nh=EAI%2C&pl=21&gcr=ae&initcwndbps=668750&mime=audio%2Fwebm&gir=yes&clen=131553647&dur=8187.981&lmt=1571677588623141&mt=1572093104&fvip=2&keepalive=yes&fexp=23842630&c=WEB&txp=5431432&sparams=expire%2Cei%2Cip%2Cid%2Citag%2Csource%2Crequiressl%2Cgcr%2Cmime%2Cgir%2Cclen%2Cdur%2Clmt&sig=ALgxI2wwRAIgL583QwmQ80aDswGUxVyMxGmNJPaWGpnA_l1mDvXD0w8CIHIKMrjJ9TZz5WjM5VPgFFSaoaxVy6r_2j4k18mOeBBt&lsparams=mm%2Cmn%2Cms%2Cmv%2Cmvi%2Cnh%2Cpl%2Cinitcwndbps&lsig=AHylml4wRgIhANmfZsBSjq3pgIj_GENEGCwlOzTTg_UdNEBiFzb-_bYFAiEAnfRO2gAzNLx5P7eMgCOlNrPyRX5msEpv-B6eygddJoo%3D&ratebypass=yes" -map 0:v -map 1:a -t 0:08 -c:v libx264 -c:a aac FILENAME.mkv
    Voilą
