Good morning,
I need to convert 4K HDR MKV movies to 4K SDR MP4 x264 movies
I need to convert the movie to mp4 format because I need it to work in streaming via a html 5 player.
I tried to convert the movie using HandBrake, but unfortunately the result is an mp4 file with colors off and without contrast.
I read that this is due to the fact that the MKV HDR movie must be converted to SDR with a color repacking.
I was wondering what was the easiest and fastest way to convert movies with the right colors ..
Does anyone know how to help me?![]()
I've seen techiestuffs recommended winx video converter being able to convert 4k videos. You can have a try.
you can see here https://forum.doom9.org/showthread.php?t=175125 (#12) or
currently RipBot has the setting 'tonemap'
[Attachment 52250 - Click to enlarge]責任者-MDX -
Only if you do care that the colors don't appear washed out when the HDR information gets ignored.I read that this is due to the fact that the MKV HDR movie must be converted to SDR with a color repacking.
Aside from the mentioned tools NVEncC and ffmpeg both support converting HDR to SDR content using the gpu in case command line tools are preferred,...I was wondering what was the easiest and fastest way to convert movies with the right colors ..
About the right colors: There are no 'right' colors since SDR by nature can't show the same color spectrum as HDR and there is no 'one correct'-mapping of the HDR onto the SDR color spectrum.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Converting UHD HDR to SDR?
By tommy2010 in forum Blu-ray RippingReplies: 9Last Post: 19th Mar 2021, 04:12 -
FFMPEG Prores mov to 4K HDR Mp4 or Mkv
By ceppu36 in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2019, 16:58 -
"Restore SDR" or "Remove HDR" its possible?
By danfgtn in forum Newbie / General discussionsReplies: 7Last Post: 7th Jul 2018, 16:33 -
HDR to SDR Avisynth+
By tommy2010 in forum Video ConversionReplies: 2Last Post: 7th Jan 2018, 17:51 -
Fix my MP4 for payment (it's home-made porn btw if that helps)
By Throwmeaway in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2014, 07:32
