Hi everyone,
i recorded a lot of TV Shows from a german television channel and now i want to store them on a NAS to stream them to different devices. (wdtv, tablets )
Mediainfo says that they are interlaced and have 25fps. When i look at the .ts files, Iīm pretty sure that most of the frames are real interlaced but some frames seems to be progressive.
The last two days i kept reading and reading about deinterlacing and the most recommend way (with handbrake), for an 1080i 25fps source, is to use yadif and bob (double frame rate) to reencoded to 1080p 50fps.
Now i did a few test with handbrake (Deinterlace: yadif / Preset: bob / Interlace Detection: Off / FPS: Same as source) and it think that it looks good.
Questions:
1. Are the videos real interlaced and 25fps? (Maybe they are interlaced but encoded progressive or they are progressive but encoded interlaced or 50 fps instead of 25 or whatever)
2. What do you think is the best way to deinterlace these videos? (To let the device deinterlace is no option for me)
3. Is handbrakes yadif-bob combination good enough for this source quality or is it possible to get much better results with QTGMC? (I have read a couple times that handbrake does the job really well if the source is good HD quality.)
Thank you in advance!
I only checked the first sample. It's phase-shifted. It's progressive but the fields are paired with the wrong partner and appear to be interlaced. Rather than this (where capital letter is top field and small letter is bottom field):
you've got this:Code:ABCDEFG abcdefg
It appears to be interlaced. To fix it you need to realign the fields to make it progressive again. In AviSynth a simple TFM() (from the TIVTC filter) easily fixes it. I don't know (and care even less) if Handbrake can do it properly.Code:ABCDEFG bcdefgh
Again, I only checked the first one. It doesn't need deinterlacing, but only field matching.2. What do you think is the best way to deinterlace these videos?Last edited by manono; 21st Oct 2019 at 17:15.
I agree with manono
#1 is field shifted, actually progressive content
#2,3 are 50 fields/s interlaced TFF content , but parts are poorly converted from their 59.94 field/s interlaced American counterpart. Especially in #3, you can see field drops (motion is not smooth, there are "jumps") -
As was already discussed, sample1 should be inverse telecined. For the other two QTGMC() is best. Yadif(mode=1) is of lesser quality but much faster.
Only you can answer that question. It's a value judgement.
Why bother reencoding them at all? Most devices can play interlaced AVC properly. You should just remux them to MP4 or MKV if your players don't support TS. -
Thank you guys. That helped me a lot!
I expected that the best solution would be avisynth and already looked at it but after it wouldnīt even load the ts files without demuxing (I think it needs DGAVCDecode for the AVC-MPEG4), it seems very complex and would take me several hours to learn how to use it. Because of that I hoped handbrake could do the job.
That is what i meant with: "...most of the frames are real interlaced but some frames seems to be progressive."#2,3 are 50 fields/s interlaced TFF content , but parts are poorly converted from their 59.94 field/s interlaced American counterpart. Especially in #3, you can see field drops (motion is not smooth, there are "jumps")
I donīt think for me it worths to use QTGMC because of the small percent of better qualityand in total there are about 200 episodes.As was already discussed, sample1 should be inverse telecined. For the other two QTGMC() is best. Yadif(mode=1) is of lesser quality but much faster. Only you can answer that question. It's a value judgement.
Because it lags and freezes when I jump to another minute, even if i remux them to mkv and the wdtv, as far as I know, canīt even deinterlace.Why bother reencoding them at all? Most devices can play interlaced AVC properly. You should just remux them to MP4 or MKV if your players don't support TS.
Not as easy as i hoped it would be.
Greetings from germany -
You need a source filter for TS files. LSMASMSource's LWLibavVideoSource() will work. Or ffmpegSoure's ffVideoSource().
http://avisynth.nl/index.php/LSMASHSource
http://avisynth.nl/index.php/FFmpegSource
Handbrake's Deinterlace
ecomb should work OK for sample1. Though the full video may have fully interlaced sections like the other samples. It's probably safest to yadif+bob.
Pauses while seeking will be a problem with any long GOP HD encoding.
My old WDTV Live had adequate deinterlacing.
Looking for a 1080i deinterlacing Capture device with full surround audio
By thghgv in forum Capturing and VCRReplies: 7Last Post: 15th Sep 2018, 17:19 -
Deinterlacing inverse telecined video
By Colek in forum Video ConversionReplies: 4Last Post: 9th Aug 2016, 09:51 -
Video analysis software
By Laurent L in forum EditingReplies: 1Last Post: 3rd May 2016, 09:38 -
Target framerate for converting a video from 1080i
By Knocks in forum Video ConversionReplies: 12Last Post: 26th Jan 2015, 11:29 -
1080i video containing 4:3 material stretched to 16:9
By tom1649 in forum Video ConversionReplies: 5Last Post: 18th Dec 2014, 09:02
