Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Jul 2018
    Indiana
    So I have some 24-bit / 48000kz audio flac files that I play on my music software at the same input quality and use an equalizer along with it. I can't get the same sound if I equalize it in audio editing software so I thought maybe I could record the audio playing through my laptop and save it that way. Is there any recommended software that would record at the same bit depth and sample rate?
  2. Member dellsam34's Avatar
    Jan 2016
    Paris Ca, 92345 Mexico
    You will be loosing a lot of quality if you record out of the analog output of an equalizer, Just use a different audio software if you don't like the one you have, audio quality loss out of a DSP is a lot less than converting to analog and back to digital.
  3. Use Audacity and record the "What you hear" device. That's the digital data after processing and before being converted to analog (the digital data being sent to the audio DAC).
