I have some footage on my SD card captured by my Camcorder XA11 in AVCHD. I am trying to view it on my television. My tv is not recognizing it. I used a external SD card reader usb device and plugged into my TV. My tv did not recognize it. I then tried the external SD card reader in my Blu-ray player and that did not recognize it. Can someone help me with a solution if there is one. I am thinking it will not read the AVCHD format but I could totally be wrong. Not sure what the problem is.
	Are the AVCHD files in folder form?That's usually what AVCHD means,if they are you need to convert to mkv or mp4 so the tv can play them. I think,therefore i am a hamster.
	ON the other hand, if the file is *.mts or similar, muxing to an MKV with MKVtoolnix may work
	Johns o, they are in folder form. My tv is older lcd Toshiba,40FT2U. Can I change to mp4 with mkvtoolnix?
	Nope,you change them to mkv with mkvtoolnix ,most newer players will play mkv so give it a try. I think,therefore i am a hamster.
  Video View IssuesBy Loobie in forum Video ConversionReplies: 16Last Post: 10th Oct 2017, 13:07
  I Can't View Videos at TwitterBy HartsVideo in forum Video Streaming DownloadingReplies: 9Last Post: 1st Feb 2017, 04:22
  Is it possible to view videos on a camera?By YeshyyyK in forum Newbie / General discussionsReplies: 15Last Post: 23rd Nov 2016, 10:14
  VirtualDub - pane viewBy pooksahib in forum Video ConversionReplies: 3Last Post: 10th May 2016, 12:10
  Can't View m2t file?By techiejustin in forum MacReplies: 8Last Post: 23rd Feb 2016, 09:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
