I have a DIVX movie with this specifications
Video
Frame size (us per frame): 512 x 272
FPS: 29.970 (33367us)
# of frames (time): 204434 (1:53:41)
Decompressor: Divx :-) MPEG-4 Low Motion
Number of keyframes: 682
Min/avg/max/total key frame size: 687 / 8844 / 25122 (5891k)
Min/avg/max/total delta frame size: 70 / 2995 / 42147 (587991k)
Audio
Sampling rate: 48000
Channels: 2 (stereo)
Sample precision: 0-bit
Compression: Frau IIS Mpeg Layer 3 codec
Preload skew: 0 samples (0.00s)
# of frames: 7049
Min/avg/max/total frame size: 14911 / 15485 / 15919 (106602 k)
I want to edit this in Premiere 6.0 and after that, put it on videotape. I think it should be possible to prepare it in a format with wich Premiere can work, probably with VirtualDub. I have Virtual Dub 1.4, only I don't know how to set the specifications for filter, compression etc.
I'm used to work with the DV500 from Pinaccle, with it's format Pinnacle DV Pal
720 - 576
25 fps
25 mbit/s
PAR D1/DV PAL (1.067)
but i should be able to work with one of the other formats as well
You can also see my specifications here: http://oneman.50megs.com/index.html
Anybody can help me?
Results 1 to 1 of 1
Change video to another format?
By Venessa@123 in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2011, 02:10 -
Possible to encode a Premiere Pro video in DivX format? (total noob seeks advice)
By metathran in forum EditingReplies: 24Last Post: 30th Jan 2010, 20:55 -
Please Help !!! How to change the audio format (only) of an Xvid/AVI ??
By moiz in forum User guidesReplies: 3Last Post: 15th Oct 2008, 12:30 -
Premiere - how do I change capture format?
By djbryson in forum Capturing and VCRReplies: 15Last Post: 17th Nov 2007, 09:42 -
Can I Change Format???
By jmarkt in forum Authoring (DVD)Replies: 2Last Post: 30th Jul 2007, 15:48
