    Oct 2019
    China
    My workmate sent me an H.264 encoded MP4 video file.
    When I use Get Info in macOS, it's dimensions is 1125x2436. However, if I open the file in Quicktime Player or VLC and check the metadata, they all display 1126x2436 instead.
    Also ffprobe says it's yuv420p, 1126x2436. Check the image below.
    [Attachment 50604 - Click to enlarge]
    I found an app called Subler earlier. It displays the video's metadata as shown below.
    [Attachment 50605 - Click to enlarge]
    After I generate a video using ffmpeg of size 1126x2436, how do I make the system display 1125x2436 without changing the real dimension? I'm looking for a tool which can do this in Linux command line.
    I know this sounds a bit weird, but my client requests that dimension because the iPhone X's screen resolution is 1125x2436 and he wants the exact fit.
    Any ideas? Thanks.
  2. Set the SAR to 1125:1126. Or DAR to 1125:2436.
    Oct 2019
    China
    Thanks for pointing out the properties.
    When I directly set
    -vf setsar=sar=1125/1126
    or
    -vf setdar=dar=1125/2436
    using ffmpeg, the output file still says dimension 1126x2436 or 1124x2436.
    However, I can also use mlt(qmelt) in my case. By adding
    sample_aspect_num="1125" sample_aspect_den="1126" display_aspect_num="1125" display_aspect_den="2436"
    to the <profile /> of the XML, the result is exactly what I want.
