I have just purchased my first Hi-Res audio player, a Sony NWA45 16GB , plus a 128GB SD card for extra storage. Being interested in the best Audio qulaity rather than storage capacity, what is the best format to rip a CD in.
Im not looking to do it with my whole collection but im interested in purchasing Hi-Res versions of my very favourite albums, has anyone got any advice on getting the best quality from reputable sits.....
Results 1 to 11 of 11
AnonymousGuest
Well best would be pcm wav, it is lossless.
Flac is certainly a very good alternative and lossless too, with a smaller file size than pcm wav -
Please excuse my nievity, If I download a Hi-res album, it will "in theory" be a better audio quality than a ripped CD......I realise there are other factors involved but a hi-res download will be better than CD
Depending on where you "download" the album from, the .flac files could have been ripped from a cd
For Audio CD's use Exact Audio Copy EAC, After loading the CD it would look like this:
After selecting a database from the 4 listed in the red circle it will look like this:
Click on the button CMP with red arrow above to output as lossless compressed FLAC with album info and cover art loaded, When you load the albums to your smart device it would look like this (Ex: VOX Player):
if all else fails read the manual
My question: is there such thing as an ACTUAL "Hi-Res" walkmanCode:
Ripping a CD for Hi res Sony Walkman
OR/AND Hi-Res earphones /headphones, by the way
"Programmers are human-shaped machines that transform alcohol into bugs." -
Just as with DVDs and Blu-Rays, a CD rip is an exact bit for bit copy contents of the CD. You can't "rip" to anything else but an uncompressed .wav. EAC has long been the most respected and recommended program for CD ripping. If you want the absolute best quality with zero error corrections, you may have to try several different drives (including CD ROM only drives) to get error free ripping.
An error free uncompressed .wav s the highest quality you can get from a CD. Flac is XX% identical to an uncompressed .wav, with some audiophiles claiming there is an audible difference.
This article https://www.whathifi.com/us/advice/high-resolution-audio-everything-you-need-to-know lists the different Hi-Res audio formats:
WAV (hi-res): The standard format all CDs are encoded in. Great sound quality but it's uncompressed, meaning huge file sizes (especially for hi-res files). It has poor metadata support (that is, album artwork, artist and song title information).
AIFF (hi-res): Apple's alternative to WAV, with better metadata support. It is lossless and uncompressed (so big file sizes), but not massively popular.
FLAC (hi-res): This lossless compression format supports hi-res sample rates, takes up about half the space of WAV, and stores metadata. It's royalty-free and widely supported (though not by Apple) and is considered the preferred format for downloading and storing hi-res albums.
ALAC (hi-res): Apple's own lossless compression format also does hi-res, stores metadata and takes up half the space of WAV. An iTunes- and iOS-friendly alternative to FLAC.
DSD (hi-res): The single-bit format used for Super Audio CDs. It comes in 2.8mHz, 5.6mHz and 11.2mHz varieties, but isn't widely supported.
MQA (hi-res): A lossless compression format that packages hi-res files with more emphasis on the time domain. Used for Tidal Masters hi-res streaming, but has limited support across products.
And this review https://www.whathifi.com/us/reviews/sony-nw-a45 states the player supports: .wav, .flac, .alac, .dsd, and .mqa
Bottom line. Uncompressed .wav is the highest quality you can get from a CD with .flac offering XX% of the quality at ~50% size savings.
As for getting other Hi-Res files, research the bitrate for each of the other formats and compare them to the file size offered. Just because it's in a non-.wav or .flac container, it doesn't mean it's the exact same file as the original recording. -
making high res to low res
By David Banner in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2019, 06:20 -
Huappauge hd prv 60 keep 4k res
By conz922 in forum Capturing and VCRReplies: 1Last Post: 24th Apr 2018, 16:21 -
Walkman or Cassette Deck to capture audio on computer?
By digicube in forum AudioReplies: 11Last Post: 26th Aug 2016, 22:28 -
MPC and full res screengrab.
By igniz12000 in forum Software PlayingReplies: 3Last Post: 10th May 2016, 15:53 -
Changing Res/clarity of subs in MP-HC
By Gurd99 in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2015, 03:31
