    Oct 2019
    Naples
    Hi
    i am trying to reauthoring the Aladdin 3D Bluray to replace italian track to original french audio track.
    Now i have this structure:
    Audio Tracks:
    1. English
    2. English (Description)
    3. French
    4. Deutsch
    Subtitles:
    1. English
    2. French
    3. Deutsch
    4. French (dummy i think)
    I do all Known procedures and all is ok, in the specific i replace french language with italian, and i do the same with subtitles, but i noted when i start with cyberlink
    PowerDVD the new Bluray folder happen:
    English, Deutsch: Subtitles Disabled
    Italian (first was french) Enable by default the number 4 subtitles.
    I'd like to disable in the Italian track too, how do this...i am crazying with DvdEdit but i see only numbers
    If You have pleasure help me
    Thanks in advance
    Oct 2019
    Naples
    Thanks very much. I received so many responses.....
  3. Anonymous19484
    Guest
    You can also think about it that if anyone has a good idea to help you they would have said it here..
    I personally don't re-author disks any more so can't help.
    And i'm not sure if DvdEdit will re-author a bluray..
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    EAsiest thing to do is to make a MKV file from the original disc using MakeMKV and unticking any tracks you don't want. Then once you have the MKV file run it through MKvToolNix and mark the tracks to be the default. MakeMKV doesn't alter the quality or shrink the file. What you put in you get out.
  5. Member Ennio's Avatar
    May 2005
    Netherlands
    There is also the possibility to remux to 3DBD iso "movie-only" with tsMuxer. You can choose to keep only the tracks you want. You'll need a decrypted ISO mounted, or decrypted BD folder structure on hard drive for input. tsMuxer will not decrypt your BD like MakeMKV does.
  6. Member Daniel-J's Avatar
    Nov 2019
    Australia
    Oh, I did that, by the way, I did well.
