  1. Member stax76's Avatar
    Nov 2009
    On thin ice
    Version 2.0 is out, included are three advanced functions that are supposed to cover everything a PowerShell user could ask for.
    It's super fast on the second run due to caching and due to the hardware accelerated WPF based Out-GridView.
    https://github.com/stax76/Get-MediaInfo
  2. Member hydra3333's Avatar
    Oct 2009
    Australia
    Thanks !
  3. Member stax76's Avatar
    Nov 2009
    On thin ice
    You are welcome. Nice to see powershell users around here.
  4. Member stax76's Avatar
    Nov 2009
    On thin ice
    Changes in Version 3.3:
    - issue with some relative and network input paths fixed by using Convert-Path
    - $ErrorActionPreference='Stop' removed because it doesn't make sense to dot source this in the profile because it's not the default
    - MediaInfoNET.dll renamed to MediaInfoSharp.dll because Get-MediaInfo and MediaInfoNET.dll are used in MediaInfo.NET and there it caused a bug due to a namespace name clash, settings dialog cannot be opened after the Folder View was shown using Get-MediaInfo, new MediaInfo.NET version will be released soon
    - improved website
    - issue fixed loading MediaInfoSharp.dll, no longer relies on changing the process path env var.
  5. Member stax76's Avatar
    Nov 2009
    On thin ice
    Version 3.7 is available, in includes the latest version of MediaInfo which was released last week, and it fixes issues with file paths containing certain characters like brackets.
