Hi Friends
I have got few .ASF DVR footage files from local law enforcement agency. Files are not playing and could be corrupt I am not sure about them.
Is there any way to repair / convert them.
Here is some more details of the same -
Filename: HCVR_ch13_main_20161016101500_20161016110000.asf
DOS Name: HCVR_C~1.ASF
Date: Created: 10/17/2019 08:11:00PM
Extensions: .WMV .WMA .ASF .ASR .DVR-MS
MIME: video/x-ms-asf
video/x-ms-asf-plugin
video/x-ms-wm
application/vnd.ms-asf
audio/x-asf
Platforms: MS Windows
Storage: Binary, Bitmap/Raster, Digital Audio, Compressed
Content: Video, Graphic Image, Personal/User Data, Sound/Audio
Best Accuracy: HIGH
Notes: This file contains highly compressed Audio and/or
Video. The file extension WMV is used for Audio/Video
files, and the WMA extension is used for Audio-only
files.
TECHNICAL DETAILS
ASCII Header: 0&²uŽfϦÙ.ª.bÎlG..........¡Ü
Hex. Header: 30 26 B2 75 8E 66 CF 11 A6 D9 00 AA 00 62 CE 6C
47 01 00 00 00 00 00 00 03 00 00 00 01 02 A1 DC
I can share with anyone for further analysis.
Thank you
Regards
sang
1) An actual MediaInfo report would be better.
2) So you mean that not even Windows Media Player can play those files?
3) DVR-MS is an asf that contains MPEG-2 video plus MPEG-1 or AC-3 audio multiplexed in non-standard ways
Which can become even worse when the application was written by incompetent programmers...
4) If possible you should store (temporarily) the problematic files in a file-sharing site, so that other members can examine them."Programmers are human-shaped machines that transform alcohol into bugs." -
hi videobruger & EL Heggunte Good morning.
Thanks a lot for your valuable help.
I have run mediainfo as suggested by you ,we have got report of the same. Video contains some crime scene , when police submitted it in court ,it refused to play.dont know whether it is tampered or exact reason for the same.
I have also uploaded it so that experts like you can check what is the issue.
here is download link -
https://drive.google.com/file/d/1iWpc0PNX8eaWzSHPJK_0ZxsUY5_qaxw1/view?usp=sharing
Thank youLast edited by chipsang; 17th Oct 2019 at 23:23.
Humm, those ASFs contain H.264 video
But that's not the actual problem, the actual problem is they are broken by design
Even Windows Media Player 12 cannot handle them.
For 2 of those 4 files, MPlayer shows only the first frame (OR one of the first frames).
libavformat cannot demux them, so both mpv and MPC-HC will not play them.
So you'd better ask the INCOMPETENT law enforcement agency to convert those files to a watchable format...
FWIW, below is what MPlayer reported while trying to play the pesky """videos""":
Code:[D:\TESTS\USB Drive\data0\MMC2] => mplayer HCVR_ch2_main_20161016105000_20161016110002.asf MPlayer SVN-r38150-9.1.0 (C) 2000-2019 MPlayer Team 224 audio & 453 video codecs Playing HCVR_ch2_main_20161016105000_20161016110002.asf. Cache fill: 0.00% (0 bytes) libavformat version 58.28.102 (internal) ASF file format detected. [asfheader] Video stream found, -vid 2 VIDEO: [H264] 1280x720 24bpp 1000.000 fps 0.0 kbps ( 0.0 kbyte/s) ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 58.53.101 (internal) Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264) ========================================================================== Load subtitles in ./ Audio: no sound Starting playback... [h264 @ 0000000001aed500]No start code is found. [h264 @ 0000000001aed500]Error splitting the input into NAL units. [h264 @ 0000000001aed500]left block unavailable for requested intra mode [h264 @ 0000000001aed500]error while decoding MB 0 32, bytestream 200 I[nhv2a6l4i d@ f0r0a0m0e0 0d0u0r0a1taieodn5 0v0a]lcuoen c(e6a7l5i2n8g4 .1507819/ 0D.C0,8 01 0=8 >9 -A6C7,5 218048.94 9M1V) .e rDreofrasu litni nIg ftroa m4e1 95.328 sec. [h264 @ 0000000001aed500]No start code is found. [h264 @ 0000000001aed500]Error splitting the input into NAL units. [h264 @ 0000000001aed500]No start code is found. [h264 @ 0000000001aed500]Error splitting the input into NAL units. Movie-Aspect is 1.78:1 - prescaling to correct movie aspect. VO: [direct3d] 1280x720 => 1280x720 Planar YV12 Invalid frame duration value (2013265.946/66.248 => -2013199.698). Defaulting to 2013265.875 sec . [h264 @ 0000000001aed500]No start code is found. [h264 @ 0000000001aed500]Error splitting the input into NAL units. Error while decoding frame! Invalid frame duration value (66.248/0.240 => -66.008). Defaulting to 2013265.875 sec. [h264 @ 0000000001aed500]No start code is found. [h264 @ 0000000001aed500]Error splitting the input into NAL units. Error while decoding frame! [h264 @ 0000000001aed500]No start code is found. [h264 @ 0000000001aed500]Error splitting the input into NAL units. Error while decoding frame! Invalid frame duration value (33554.712/0.320 => -33554.392). Defaulting to 33554.473 sec. [h264 @ 0000000001aed500]No start code is found. [h264 @ 0000000001aed500]Error splitting the input into NAL units. Error while decoding frame! [h264 @ 0000000001aed500]Invalid NAL unit 7, skipping. [h264 @ 0000000001aed500]no frame! Error while decoding frame! Error while decoding frame! [h264 @ 0000000001aed500]top block unavailable for requested intra mode [h264 @ 0000000001aed500][h264 @ 0000000001aed500]No start code is found. error while decoding MB 54 0, bytestream 2012 [[hh226644 @@ 00000000000000000011aaeedd550000]]Ecrornocre aslpilnigt t3i5n9g5 tDhCe, i3n5p9 u5t AiCn,t o3 5N9A5L MuVn ietrsr.o rEsr rionr Pw hfirlaem ed ecoding frame! Invalid frame duration value (17.024/0.720 => -16.304). Defaulting to 16.584 sec. Error [whh2i6l4e @d e0c0o0d0i0n0g0 0f0r1aameed!5 00[]hc2o6n4c e@a l0i0n0g0 030302020 1DaCe,d 530302]2t oApC ,b l3o3c2k2 uMnVa vearirloarbsl ei n f oPr frreaqmuee sted intra mode [h264 @ 0000000001aed500]error while decoding MB 1 0, bytestream 3040 [h264 @ 0000000001aed500]concealing 3600 DC, 3600 AC, 3600 MV errors in P frame Exiting... (Quit) [D:\TESTS\USB Drive\data0\MMC2] => mplayer HCVR_ch2_main_20161016110002_20161016111501.asf MPlayer SVN-r38150-9.1.0 (C) 2000-2019 MPlayer Team 224 audio & 453 video codecs Playing HCVR_ch2_main_20161016110002_20161016111501.asf. Cache fill: 0.00% (0 bytes) libavformat version 58.28.102 (internal) libavformat file format detected. LAVF_header: av_open_input_stream() failed Exiting... (End of file) [D:\TESTS\USB Drive\data0\MMC1] => mplayer HCVR_ch13_main_20161016101500_20161016110000.asf MPlayer SVN-r38150-9.1.0 (C) 2000-2019 MPlayer Team 224 audio & 453 video codecs Playing HCVR_ch13_main_20161016101500_20161016110000.asf. Cache fill: 0.00% (0 bytes) libavformat version 58.28.102 (internal) ASF file format detected. [asfheader] Video stream found, -vid 2 VIDEO: [H264] 1280x720 24bpp 1000.000 fps 0.0 kbps ( 0.0 kbyte/s) ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 58.53.101 (internal) Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264) ========================================================================== Load subtitles in ./ Audio: no sound Starting playback... Invali[dh 2f6r4a m@e 0d0u0r0a0t0i0o0n0 2vaa5ldu5e0 0(]1c.o1n4c4e/a0l.i4n2g4 3=5>5 8- 0D.C7,2 0 3)5.5 8D eAfCa,u l3t5i5n8g MtVo e1r.r0o6r4s sienc .P fra[mhe2 6[4h 2@6 40 0@0 00000000000020a050d25a050d]5I0n0v]acloindc eNaAlLi nugn i1t3 20 ,D Cs,k i1p3p2i nAgC., [1h3226 4M V@ e0r0r0o0r0s0 0i0n0 2Ia 5fdr5a0m0e] no frame! Invalid frame duration value (0.424/0.200 => -0.224). Defaulting to 1.064 sec. Movie-Aspect is 1.78:1 - prescaling to correct movie aspect. [h264 @ 0000000002a5d500]concealing 3562 DC, 3562 AC, 3562 MV errors in P frame VO: [direct3d] 1280x720 => 1280x720 Planar YV12 Invalid frame duration value (0.200/0.000 => -0.200). Defaulting to 1.064 sec. [h264 @ 0000000002a5d500]left block unavailable for requested intra4x4 mode -1 [h264 @ 0000000002a5d500]error while decoding MB 0 2, bytestream 4476 [h264 @ 0000000002a5d500]concealing 3489 DC, 3489 AC, 3489 MV errors in P frame [h264 @ 0000000002a5d500]No start code is found. [h264 @ 0000000002a5d500]Error splitting the input into NAL units. Error while decoding frame! Invalid frame duration value (1275330.661/0.600 => -1275330.061). Defaulting to 1275330.625 sec. [h264 @ 0000000002a5d500]No start code is found. [h264 @ 0000000002a5d500]Error splitting the input into NAL units. [h264 @ 0000000002a5d500]No start code is found. [h264 @ 0000000002a5d500]Error splitting the input into NAL units. Exiting... (Quit) [D:\TESTS\USB Drive\data0\MMC1] => mplayer HCVR_ch13_main_20161016110001_20161016113001.asf MPlayer SVN-r38150-9.1.0 (C) 2000-2019 MPlayer Team 224 audio & 453 video codecs Playing HCVR_ch13_main_20161016110001_20161016113001.asf. Cache fill: 0.00% (0 bytes) libavformat version 58.28.102 (internal) Exiting... (End of file) [D:\TESTS\USB Drive\data0\MMC1] =>
Hi El Heggunte
You are great , appreciate your technical expertise.
Actually these peoples are dumb and they know nothing about file format. Dont know how files are broken ,may be tampered intentionally.
I think cant do anything now.
Thanks a lot for all the efforts.
AMR file repair/recovery
By AMR in forum AudioReplies: 1Last Post: 5th Dec 2020, 21:28 -
Need to repair Skype Video Call AVI file!
By DWCJedi in forum Newbie / General discussionsReplies: 17Last Post: 12th May 2017, 19:27 -
Repair damaged MKV file
By robnyt in forum DVD RippingReplies: 1Last Post: 25th Dec 2015, 17:53 -
Help, is it possible to still repair/fix this asf file?
By nevskycollins in forum Video ConversionReplies: 6Last Post: 12th Nov 2015, 21:37 -
Improve or Repair Video File's Quality
By WazaKrash in forum RestorationReplies: 11Last Post: 12th Mar 2015, 10:43
