If already discussed, forgive please.
I have installed WinCDEmu. I then cliked the iso file and cliked open. It seems this app automatically activated from clik of the selected iso and created a virtual drive of the iso. I don't even think I am using the correct terminology. Anyways I have opened the new drive labeled 'BD-ROM Drive (V) Filename'. I have attached an image of the 'opened' drive. These folders are unfamiliar to me and I ask what I do next.I am guessing there is bluray audio or video or both or ...
-thank you
You haven't asked for any other help then what's in the iso,do you need to burn it as a blu-ray disc or extract it to edit/re-encode it?
What do want to do? Seems to be a blu-ray, have you tried playing it in VLC or MPC-HC?
If that software mounted a virtual drive, it's as if an actual disk was inserted ie. it has a drive letter,
etc,etc, Just play it
Don't really need to install a software for that if you're using Windows 8 or newer ISO mounting built in, just right click the iso and select mount -
Play 3D ISO's on PC.
By ebruce in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jun 2019, 11:42 -
Ripping to ISO?
By ET3D in forum DVD RippingReplies: 4Last Post: 14th Apr 2017, 10:42 -
VIDEO_TS to ISO
By TheLastOfThem in forum Video ConversionReplies: 6Last Post: 21st Jul 2016, 19:29 -
Burning ISO Error
By PowerFalcon in forum Authoring (DVD)Replies: 6Last Post: 30th Oct 2015, 22:23 -
DVD to ISO again
By 123fish123 in forum DVD RippingReplies: 9Last Post: 7th Mar 2015, 15:48
