I've studied the thread:
https://www.videohelp.com/dvdhacks/lg-bp250/12580
But there are contradictory posts as to whether this will work for the LG BP 250. Is there any risk in trying it? IOW, can these hacks (playing a specially burned CD) damage the player?
Terry
No one with any suggestions please? Or have I posted in an inappropriate forum?
what country is your player from ??
it'll be just for the DVD side of the player, the blu-ray side will still be locked.
there shouldn't be any risks, not that I've seen. -
I'm in UK and it was bought in UK.
So, if I can get that hack to work (I will try it soon) it will still be unable to play some of my son's Blu-ray discs bought in USA?
Is there no hack for blu-ray players?
BTW, is that the correct term, or are these called 'BD players'? -
'BD Player' is just an acronym for Blu-Ray Disk Player.
Can not answer your Q. re availability of hacks for the Blu Ray side of players but there are available specially adapted players that are not supported by the original manufacturer.
https://www.amazon.co.uk/s?k=region+free+blu+ray+player&crid=QUJZG40TUWV1&sprefix=regi...b_sb_ss_i_1_15 -
The industry has a very tight grip on region free hacks for playing Blu-ray discs. There are only a few players with hacks for that. And most of those hacks can't be done from the standard remote control. It's something you should have looked into before buytin a Blu-ray player.
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 01:11 -
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 07:32 -
Blu Ray iso on a DVD...will it work on a Blu Ray player?
By DumdogsWorld in forum Newbie / General discussionsReplies: 5Last Post: 25th Nov 2016, 04:09 -
Sony BDPS5500 Blu-ray Player VS Samsung BD-J5700 Blu-ray Player
By tarzan54 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Jan 2016, 19:51 -
changing the screen saver image on Oppo blu ray player?
By nodnarb in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Nov 2014, 21:38
