Thanks![]()
Take the Brackets '[]' out of -ss time and clip time and designate a correct output folder:
for %%a in (*mkv) Do ffmpeg -i "%%a" -ss 00:00:20 -t 30 "c:\pathToOutputFolder\NewName_%%a"
or
for %%a in (*mkv) Do ffmpeg -i "%%a" -ss 00:00:20 -t 30 "c:\pathToOutputFolder\%%a"
HOWEVER, if you are cutting at a non Key Frame, You may get junk that is unplayable. The latest ffmpegs allow cutting at Key frames but
you must specify the exact frame time (e.g. 00.00.20.040). It is possible but unlikely that all your MKV files have a key frame at the same location
so batch cutting would result in unknown results.
batch merge videos and audios with ffmpeg
By m0ck in forum Video ConversionReplies: 6Last Post: 27th May 2021, 08:12 -
Batch trim end of multiple length videos
By Budman1 in forum Video ConversionReplies: 3Last Post: 10th Dec 2019, 06:22 -
ffmpeg is there any way to trim a video and hardcore subtitle at once?
By Anonymous98434 in forum Video ConversionReplies: 1Last Post: 16th Aug 2018, 06:49 -
ffmpeg trim + concat = Non-monotonous DTS errors
By TorBru in forum Video ConversionReplies: 9Last Post: 27th Dec 2015, 05:33 -
how to trim in FFMPEG?
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 5th Apr 2015, 10:04
